Clutch Shudder
Mk2EscortSport!
Hi,
Got a couple of little problems with the daily. Clutch shudder in my 86 laser. Anyone know if there is a common problem with these cars that causes this? Had a look at the haynes manual and it suggests engine, gearbox mounts, warped pressure plate, or a glazed clutch?. Does anyone know a way to figure out which it could be? Cheers Jason
If you're refacing the flywheel... WHATEVER YOU DO DON'T REUSE THE FLYWHEEL BOLTS!!!!
I know from bitter experience how difficult it is to get the studs out of the crankshaft.
Huh? The friction face of the flywheel is usually well proud of the crank mating face. The original bolts will be fine.......... unless Lasers have some wierd flywheel that I don't know anything about
Need to be careful you dont strip the threads in the crank aswell, I suggest you get a new crank to be sure. ;). <--- Sarcasm.
Have done many many flywheel jobs, and have never had a problem re-using flywheel bolts... Sure, occasionally you get a bolt thats messed up and shears, but that could happen anywhere, with any bolt... You going to use brand new bolts every time you replace anything?
In conclusion, re using your flywheel bolts will be fine, unless you're unrealistically unlucky, in which case you should put the spanner down and open your wallet.
