karmagedon Posted October 5, 2009 Share Posted October 5, 2009 Why not just make a restrictor plate for the tip if you're only wanting it for wof's? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 5, 2009 Share Posted October 5, 2009 What sort of loud is it If you've got a rasp issue then get a fluted coby and it'll quieten it down a fair bit. Mine is loud but is 3" and only the 1 muffler..... Quote Link to comment Share on other sites More sharing options...
Hemi Posted October 5, 2009 Share Posted October 5, 2009 What sort of loud is it If you've got a rasp issue then get a fluted coby and it'll quieten it down a fair bit. Mine is loud but is 3" and only the 1 muffler..... yea the harsh noises get taken out real good by those flute coby style mufflers . well manu in my car (which you have heard) , i have manifold 400mm , chamber and perforated tube coby followed immediatly by flute type coby . runs the rest of zorst in 2 1/4 (57mm??), then the muffler at the back (im not sure what kinda but its not straight through however you can see light ) . and its not loud at all Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 5, 2009 Share Posted October 5, 2009 cheers guys will investigate fluted coby.. yeah its a raspy loud, you can drive it sort of quietly under about 3k rpm but yeah gets loud after that Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 5, 2009 Author Share Posted October 5, 2009 wouldn't a fluted coby just alter the sound and not make it much quieter? i still rate the rage triple flow mufflers they do a big ass s-bend inside and really suck the noise out without reducing the flow too much, usually with a small reso or 'dumpy tip' they will be hushed enough for a wof Quote Link to comment Share on other sites More sharing options...
kpr Posted October 6, 2009 Share Posted October 6, 2009 on my 4age, i run a reso (4" tube with 2.5" perf thru the center, fiberglass packing) about 400-500mm long a bit after the extractors, the at the rear a biggish muffler with 2 or 3 chambers in it, bellmouth entrys into each chamber in an effort to keep flow up. its kinda tripple flow design i guess. cant remember just how i built it, else i would draw it up. then have a length of pipe after the muffler. whole system is 2.5". its pretty quiet, intake noise is way louder. a decent sized muffler (big as you can fit) with plenty of internal volume will work best. will cut down the noise more. should also flow better, depending on design of course. a decent length of pipe after the muffler and no big gay tip makes alot of difference as well. i'd grab the next size up muffler to your pipe size as well, to keep flow up. Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 6, 2009 Share Posted October 6, 2009 good info thanks! Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted October 7, 2009 Share Posted October 7, 2009 Does anyone know what the 'Flowsound' Flowmaster rip off's that are on trademe are like? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 7, 2009 Share Posted October 7, 2009 ^^^ Looks the same as the Flow fast ones but with grayer paint. Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted October 7, 2009 Share Posted October 7, 2009 What are the flow fast ones like? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 7, 2009 Author Share Posted October 7, 2009 poo Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 7, 2009 Share Posted October 7, 2009 It's fine on the race car... but that's not the greatest way to judge a muffler. Sounds good between 5000 and 8000RPM. Quote Link to comment Share on other sites More sharing options...
