TOYOPET Posted May 12, 2009 Share Posted May 12, 2009 Just wondering what gearbox is used in '81 Coronas with a 3t motor??? The one i have is a 4 speed so am looking at getting a 5 speed. Does anyone know what box it would be and what bolts up to it? Doing a search on trade me last night for "3t gearbox" the only one i found was a $500 supra box but it didnt say what it was (w50, k50, t50 etc etc) Any ideas??? p.s If this post gets deleted again can the mod that deletes it please pm me and tell me why youve deleted it. i hvae done a search and have found nothing so why delete it? Quote Link to comment Share on other sites More sharing options...
fuel Posted May 12, 2009 Share Posted May 12, 2009 I'm guessing it would be a T40, could possibly be a W40 though. I guess being NZ assembled it may not have the gearbox code stamped on the build plate on the firewall. Quote Link to comment Share on other sites More sharing options...
Alistair Posted May 12, 2009 Share Posted May 12, 2009 If the box is a "supra" then normally it would be a w* of some description although hard to tell from the angle the picture is taken on. Someone on here might be able to pick it from the photo. Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 12, 2009 Share Posted May 12, 2009 I deleted it because I don't like you Quote Link to comment Share on other sites More sharing options...
TOYOPET Posted May 12, 2009 Author Share Posted May 12, 2009 lucky im not here to make friends then aye. Anyway back on topic. Fuel: i didnt realise they stamped the gearbox code on firewall but will check that out first - the thing is the motor is not the original one it came from the factory with, its another one. im guessing its the same kind of motor tho so hopefully gearbox is the same.... what i really want to know tho is what gearbox can bolt up to the 3t. any ideas? Quote Link to comment Share on other sites More sharing options...
mikuni Posted May 12, 2009 Share Posted May 12, 2009 The import 3T came with a T40/50 generally, it was only the 3T-GTEU that came with a W55 behind it. So, a T50 box will fit behind it but if you buy one off trademe you have to be sure to get the one with the right spline count as I think a T50 from a 4A-GE or something else of a later model won't fit. Quote Link to comment Share on other sites More sharing options...
fuel Posted May 12, 2009 Share Posted May 12, 2009 yeah it should be a 20 spline box.. a shame too cause I had a 20 spline T50 with T series bellhousing not long ago. Quote Link to comment Share on other sites More sharing options...
TOYOPET Posted May 13, 2009 Author Share Posted May 13, 2009 sweet so a 20 spline T50 with t series bell housing is what i need to be looking for.... the 22 spline ones are the ones that fit into 4ages aye? wonder how hard 20 splines are to find Quote Link to comment Share on other sites More sharing options...
Ned Posted May 13, 2009 Share Posted May 13, 2009 not too hard. You can normally pick them up for $150-$300 ish. You could always go for a W55 or sim... Bit more money but stronger.. Quote Link to comment Share on other sites More sharing options...
Crownin_Round Posted May 13, 2009 Share Posted May 13, 2009 Both just as rare as each other now in some circumstances and depending on how much you wanna pay someone. Whats your corona chassis code? some St140 series come out 3t-c w40 or w50 especially in the lift back 5 speed, Bearing in mind if your current gearbox is a T40 all you need is the T50 just whack your bell housing on it and slot it in. Quote Link to comment Share on other sites More sharing options...
TOYOPET Posted May 13, 2009 Author Share Posted May 13, 2009 chassis code is TT132 and its a wagon. Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 13, 2009 Share Posted May 13, 2009 Ive seen 130 series with t series box's and W could be either depending on its origins. Simply look underneath it if its alloy bang 20 spline t40, steel w40. My bets are on T series box with T series diff Quote Link to comment Share on other sites More sharing options...
fuel Posted May 13, 2009 Share Posted May 13, 2009 it's NZ assembled so most likely weaker spec compared to imports. Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 13, 2009 Share Posted May 13, 2009 ^ my nz farm spec ones had t40's, t diff. but yea look under it Quote Link to comment Share on other sites More sharing options...
Crownin_Round Posted May 13, 2009 Share Posted May 13, 2009 Ive seen 130 series with t series box's and W could be either depending on its origins. Simply look underneath it if its alloy bang 20 spline t40, steel w40. My bets are on T series box with T series diff Thats a safe bet.. Better than having a look take a picture so we can all see! Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 13, 2009 Share Posted May 13, 2009 Spence wins. Quote Link to comment Share on other sites More sharing options...
al_feinted Posted May 14, 2009 Share Posted May 14, 2009 Coronas typically run celica gearboxes, if the motor is 1600cc or less it will have T series box, if its bigger then it will have W box... usually Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 14, 2009 Share Posted May 14, 2009 ^ na dude theres is shit loads of 3t also 1s coronas/carinas with t40/50 boxes, Ive owned maybe 4-5 130/140 coronas and a carina wagon all 3t's and one 1s all with t40/50's Quote Link to comment Share on other sites More sharing options...
Crownin_Round Posted May 15, 2009 Share Posted May 15, 2009 My mechanics girlfriend thing has a corona liftback 3t-c w50 standard, ive had a friend who owned one years ago that was w50, ive had a Ta40 carina 3t-j w40 so it could be anything. Hell ive seen a Ga61 that was 1g-eu T50 T252.. Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 15, 2009 Share Posted May 15, 2009 ^ yup depends on all sorts of things, best bet is to look at it Quote Link to comment Share on other sites More sharing options...
