tregath Posted March 10, 2009 Share Posted March 10, 2009 So i managed to scam today off work so thought id have a go at getting the front guards off. To do this, i need to get the doors off. which are not bolt on Does any one have any tips for getting the door pins out without using the grinder and hating myself afterwards? this is the beast here, will do a better write up later when i have progress Quote Link to comment Share on other sites More sharing options...
QCADTA Posted March 10, 2009 Share Posted March 10, 2009 lots of crc and a roll pin remover, or a oxy/acet. torch and apply heat and punch out. or thin hacksaw blade and cut out. usually a painful proccess. getin the guards off isnt much more fun with out ruinin your front panel, drip rail etc. Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 10, 2009 Share Posted March 10, 2009 What year mk1 is it? And are the top and bottom hinges on the doors the same? Quote Link to comment Share on other sites More sharing options...
tregath Posted March 10, 2009 Author Share Posted March 10, 2009 It is a NZ assembled 1968. they both look to be the same, Where would i obtain a roll pin remover? Im not worried if i destroy the front panel, Its allready shagged so i will have to get one from palmside at a latert date Quote Link to comment Share on other sites More sharing options...
QCADTA Posted March 10, 2009 Share Posted March 10, 2009 ampro makes them so who ever sells ampro tools where you are. click below ampro tool you want Quote Link to comment Share on other sites More sharing options...
tregath Posted March 10, 2009 Author Share Posted March 10, 2009 ty il look into finding one Quote Link to comment Share on other sites More sharing options...
QCADTA Posted March 10, 2009 Share Posted March 10, 2009 no worries, soak with crc/wd40 for a day before tryin. if that doesnt work clean off crc and apply heat and lever out. mine were a cunt as most of them are Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted March 10, 2009 Share Posted March 10, 2009 yeh as the other lads have said wd40 and heat i bought my door pin removing tools from a panel beating shop just soak the them in wd40 for a few days then stick the pin remover in and heat the fuck out of it a few good wacks with a hammer and they come flying out Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 10, 2009 Share Posted March 10, 2009 mean thread cheers guys definatly going to have to hunt down one of these tools Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted March 10, 2009 Share Posted March 10, 2009 Mine were a kent also. Used a bent screwdriver till i got the end poking out, then lpiers and vice grips to pul them clear. Fucked the pins in the process. Where will we find new pins guys? Or run bolts? Quote Link to comment Share on other sites More sharing options...
tregath Posted March 10, 2009 Author Share Posted March 10, 2009 about what sort of dollar value are the pin removal tools? I will get one and sell/loan to other posters when i have finished using it. after all i only have 4 pins to remove. PM me if you are keen to borrow one when i am finished, will post or courier Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 10, 2009 Share Posted March 10, 2009 Yeah mate could be keen if the tool works Quote Link to comment Share on other sites More sharing options...
QCADTA Posted March 11, 2009 Share Posted March 11, 2009 theyre not exspensive, was less than $40 off the top of my head. vauxhall astra mk 3 pins are a good replacement, but i used m8 bolts with a nyloc nut, easier to get off in the future. Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 11, 2009 Share Posted March 11, 2009 if you cant get heat onto it another way is to put somthing solid behind the hinge and the smash the opposite side with a hammer , it distorts the hole adn will somtimes help to break up the corrsion , similar to the way you get a tierod out Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted March 20, 2009 Share Posted March 20, 2009 Sykes Pickervant make the tool also. Or at made one. It's been a while (8 yrs) since i did myne, i borrowed the sykes tool of a workmate. If i remember right it has to be done in this unusual way because of the way the door is shaped. Maybe someone can confirm this I reckon you could make a tool easy as. A Buy a long bolt, Turn the head down so it will slide down hinge bore but is still bigger than the roll pin ID. poke through the roll pin inside the hinge, thread a nut on the other end. Then use a fork of some sort to belt down on the nut. If i remember right it has to be done in this way because of the way the door is shaped. Maybe someone can confirm this. May be more like this B Buy a long bolt and nut, Turn the nut down so it will slide down hinge bore but is still bigger than the roll pin ID. poke upwards through the roll pin inside the hinge, thread a modified nut on the other end above the roll pin. Then use a fork of some sort to belt down on the bolt head. Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted March 20, 2009 Share Posted March 20, 2009 Replacement roll pins were available at EDL fasteners in Chch based on dimensions. Blacks can probably do them too. Nothing special Quote Link to comment Share on other sites More sharing options...
tregath Posted March 20, 2009 Author Share Posted March 20, 2009 Yea i havnt had any luck. I have asked the local tool shops to source the one from ampro but cannot source one. After rigning all the panel beaters in town i have been able to borrow one of the Sykes Pickervant ones but cant get the fuckers out. starting to get angry Quote Link to comment Share on other sites More sharing options...
tregath Posted March 21, 2009 Author Share Posted March 21, 2009 SOOO close to cutting hinge off Will to pay someone to remove them Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 21, 2009 Share Posted March 21, 2009 Just had a go at mine any im having similar results ... need heat im thinking Quote Link to comment Share on other sites More sharing options...
mkcortina Posted March 21, 2009 Share Posted March 21, 2009 have managed to get any pins out? i could only get the top 1's out. i then had to move the door up and down till the pins snapped. i think the hinges are bent thats why they are hard to get out. once i snapped the pins both half's came out really easy. also you can get the remover from sulco http://www.sulco.co.nz/Product?Action=View&Product_id=911 Quote Link to comment Share on other sites More sharing options...
