eke_zetec_RWD Posted January 8, 2009 Share Posted January 8, 2009 what have you had? third time this year my number 4 exhaust rocker has jumped off the valve! wtf is going on. i can only put it down to a bent valve beign tight in the guide. really pissing me off tho!!!! seriously considering going roller rockers and cam, not many places doing these products tho!? Quote Link to comment Share on other sites More sharing options...
sholdowa Posted January 8, 2009 Share Posted January 8, 2009 There's got to be something up with that valve - maybe the head's overheated badly in the past. Or you've got the redline set at 8,500. I take it the lobe is ok?? Quote Link to comment Share on other sites More sharing options...
RT Posted January 8, 2009 Share Posted January 8, 2009 I've never had any problems, not even when I used to rev it off the clock with a 3/4 race cam lol. one thing I know is that there is an issue with rockers, you may have read that you should buy new rockers when you install a new cam. But many of the rockers we have available here are the wrong size. They fit, but not as good as std. Apparently this is because the rockers are made to suit a 1600 and a 2L.. without actually suiting either motors. So I always used the best old rockers I could find in my engines. dunno if this is actually your problem btw but I thought it would be interesting information anyway. Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 9, 2009 Share Posted January 9, 2009 Its something to do with the geometry of the head. Either Vizzard or David Baker mention it in one of their tuning guides. 1 in 10 or something similar chew the cam out they said. I have had one do it. I put it down to rockers not being machine acuratly enough. It ate the lobe down so much that the rocker fell off and it made a massive bang/novalve after around 3000ks. Set I have now I got done at Kelford and they are fine. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 9, 2009 Author Share Posted January 9, 2009 himmmm, random thing is that this head im using atm i have used before with no issues. the cam and lifters were still in mint condition when it jumps off 2 i went to hartlys head shop to see if he would redo my good head but he said he wont touch any pinto heads any more unless the owner assembles them or he uses a roller cam kit from esslinger in the usa. they 1000us a kit which all gud. that includes valves, steel cam, roller rockers, head braces, adjustable rocker pedistals and valve springs. quite keen a. but really theres no reason why mine wont work rite....... Quote Link to comment Share on other sites More sharing options...
RT Posted January 9, 2009 Share Posted January 9, 2009 just buy another set of rockers and you'll prolly be sweet. If you could get a new STD set of 2L rockers it would be best. Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted January 9, 2009 Share Posted January 9, 2009 I have heard that they can be hard to setup and that if they aren't they wear a lot. Seen this? http://www.kelford.co.nz/technicalford2000 Quote Link to comment Share on other sites More sharing options...
sholdowa Posted January 9, 2009 Share Posted January 9, 2009 a long shot, but the rear cam bearing hasn't worn has it? it's only white metal... Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2009 Author Share Posted January 10, 2009 cam bearings are mint. i dont think its the rocker cos iv replaced it and still does same thing. must be tight valve in head. will check tomorrow. gota get it sorted before rota nats Quote Link to comment Share on other sites More sharing options...
sholdowa Posted January 10, 2009 Share Posted January 10, 2009 weak spring? Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 10, 2009 Share Posted January 10, 2009 Nismo Capri had a roller rocker setup for a pinto a while back. Was for sale. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2009 Author Share Posted January 10, 2009 Nismo Capri had a roller rocker setup for a pinto a while back. Was for sale. pmd him, keen as. how long ago??? Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 11, 2009 Share Posted January 11, 2009 Bout a year ago but I think saw him advertise it again bout 3months ago. PM RT for his number if your real keen. Gaz Quote Link to comment Share on other sites More sharing options...
escorted Posted January 11, 2009 Share Posted January 11, 2009 Pinto cams are also a bastard to set the valve clearences Quote Link to comment Share on other sites More sharing options...
RT Posted January 12, 2009 Share Posted January 12, 2009 ^ yep can't say I miss doing them.. ya gotta remember to hold down the back of the rocker with your finger then slide the feeler gauge in and adjust so it just *bites* then slides through nicely. Turn cam and repeat. too tight and you'll wear everything out, too loose and everything will rattle and a rocker will fall out lol yeah nismo still has the roller rockers I think.. he might sell them I dunno. Quote Link to comment Share on other sites More sharing options...
slipsittin Posted January 12, 2009 Share Posted January 12, 2009 The retainer springs can be slightly weak too. Have you tried changing the retaining spring with another one? I replaced mine every 3 race meetings or so depending on lap count and I was pulling 9000rpm Yeah there is a trick to the valve settings but rollers can cause you issues also. You can't just get roller followers and slap them on the cam already fitted as they need a different lobe shape to follow (I made this mistake when I was very young and it cost me thousands in damage) Corey Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 14, 2009 Share Posted January 14, 2009 The retainer springs can be slightly weak too. Have you tried changing the retaining spring with another one? I was thinking the same thing. You can't just get roller followers and slap them on the cam already fitted as they need a different lobe shape to follow (I made this mistake when I was very young and it cost me thousands in damage) Corey Yep that's what had happened with these and one of them had been broken and fixed. Not that playhard said that on his auction. Luckly I got them cleaned and crack tested here at work and they are all good. Still waiting for a roller cam to turn up Quote Link to comment Share on other sites More sharing options...
slipsittin Posted January 15, 2009 Share Posted January 15, 2009 Yep that's what had happened with these and one of them had been broken and fixed. Not that playhard said that on his auction. Luckly I got them cleaned and crack tested here at work and they are all good. Still waiting for a roller cam to turn up Thats not good man I hate people who do stuff like that and set up others for costly errors Glad to hear you sorted it. Hows that head coming on? Corey Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 16, 2009 Author Share Posted January 16, 2009 new head going well, just running in on outer valve springs and will put inner springs in tonight. dyno tomorrow morning. and the prob on the old head was it had droped an exhaust seat!!! Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 16, 2009 Share Posted January 16, 2009 Oh the horror storey continues. Im guessing no other damage was done? Quote Link to comment Share on other sites More sharing options...
