d.p.n.s Posted October 18, 2008 Share Posted October 18, 2008 hi all im having a problem with my van at the moment its slowly draining the battery nissmo-capri put new bushes in my alt and it does seem to charge when its running but if i leave it over night and go to start it in the morning she pretty dead. i have been threw the wiring for the lights and sounds ect and it all turns off when the key is off. so any ideas? i put a charged battery in and it lasted 2 days when to start it thismorning and she fired into live turn it off and try it again and its dead. any help will be cool. cheers dan Quote Link to comment Share on other sites More sharing options...
QCADTA Posted October 18, 2008 Share Posted October 18, 2008 have you put a clip on ammeter on ya battery lead to see if there a current draw with the key turned off? Quote Link to comment Share on other sites More sharing options...
slipsittin Posted October 19, 2008 Share Posted October 19, 2008 Check the terminals on the battery to see if you have a good contact. Do you have an alarm or radio wired in to the full battery circuit, if so disconnet anything that is direct to the battery and see if it goes away. As said above you can check with a clamp meter but to save money just disconnect one thing at a time. Clocks are another bastard thing that can draw heaps when getting tired. Corey Quote Link to comment Share on other sites More sharing options...
sholdowa Posted October 19, 2008 Share Posted October 19, 2008 I've been caught out by the live to the radio to keep it's memory - connecting the wrong one to permanently on, and a boot light permanently on. And, of course everything on an italian car! try taking half the fuses out and seeing it that helps and so on... At least you'll work out which circuit's draining. Quote Link to comment Share on other sites More sharing options...
RT Posted October 20, 2008 Share Posted October 20, 2008 I had the same problem once, I was running subs etc and the poor old amp couldnt keep up. I fitted a late model alt from a sierra, one with the blue back on it is the best. That sorted it. I've got the same problem with my capri at the moment, I leave it for 2 weeks and somehow the battery has drained completely flat. So flat that the alarm doesn't even work. I think it must be the battery. So.. could be you battery if it's old? Mine is a expensive sealed unit but is about 5 years old so prolly fuct. Quote Link to comment Share on other sites More sharing options...
forced Posted October 20, 2008 Share Posted October 20, 2008 I'd try a "good" battery first. It might be draining itsself internally. Steve Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 20, 2008 Share Posted October 20, 2008 care to explain what a 'good' battery is? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 20, 2008 Author Share Posted October 20, 2008 I had the same problem once, I was running subs etc and the poor old amp couldnt keep up. I fitted a late model alt from a sierra, one with the blue back on it is the best. That sorted it. I've got the same problem with my capri at the moment, I leave it for 2 weeks and somehow the battery has drained completely flat. So flat that the alarm doesn't even work. I think it must be the battery. So.. could be you battery if it's old? Mine is a expensive sealed unit but is about 5 years old so prolly fuct. ive tryed 2 batterys both pretty newish lasts for about 2 days then dies nismo-capri said to try a sierra alt may just give it more of a boost. i have been threw most of the wiring aswell and all i can think is that it could be the sounds i do have to amps and 2 subs aswell but it still shouldnt drain it when its all turned off. Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted October 20, 2008 Share Posted October 20, 2008 Had something similar happen on my Surf. Charged fine, everything was in order. Fault was in the alternator, Rectifier iirc Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted October 20, 2008 Share Posted October 20, 2008 and if all else fail boats, could always go to a Kill switch Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 20, 2008 Author Share Posted October 20, 2008 and if all else fail boats, could always go to a Kill switch not a bad idea mate then the battery is cut off from everything i dont mind tuning my radio in every morning dan Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted October 20, 2008 Share Posted October 20, 2008 and a little added security if someone tries to pinch it. Quote Link to comment Share on other sites More sharing options...
RT Posted October 21, 2008 Share Posted October 21, 2008 i have been threw most of the wiring aswell and all i can think is that it could be the sounds i do have to amps and 2 subs aswell but it still shouldnt drain it when its all turned off. actually.. it can do depending on how you wired it up.. my stereo and amp slowly drained my battery simple by being connected all the time. kill switch is fine, I have one and am now trying that out to see if my battery still dies after 2 weeks of no use. If it does I know it's the battery and not being drained. However, a kill switch can also kill your alarm and your central locking which is a pain... Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted October 21, 2008 Share Posted October 21, 2008 Not if you run them off rhe "battery" side of the switch.... Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 21, 2008 Share Posted October 21, 2008 if youre lazy like me and dont want to find a proper remote supply thats on the key switch then just run a temporary one via fuse and switch from the main amp power as its right there. leave it on and the battery will drain, turn it off and it'll be sweet as and wont kill your alarm etc Quote Link to comment Share on other sites More sharing options...
sholdowa Posted October 21, 2008 Share Posted October 21, 2008 Hey Dan try disconnecting the stereo and see if that fixes it. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 21, 2008 Author Share Posted October 21, 2008 Hey Dan try disconnecting the stereo and see if that fixes it. it seems to be ok at the moment steve ive been out and started it every morning for the past 4 days and its fired up but only just. i thinking about putting a better alt on like a sierra(dont have one around the place do you mate) just to put a bit more power in the old girl and as for the cut off switch im still keen just to help stopping it being pinched. hows the lime green beast coming along mate. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted October 21, 2008 Share Posted October 21, 2008 Yeah I've got one lying around and i'll not be needing it for a while. Off a sierra. Let me know... we used to put xj6 ones on the rally cars iirc. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 21, 2008 Author Share Posted October 21, 2008 Yeah I've got one lying around and i'll not be needing it for a while. Off a sierra. Let me know... we used to put xj6 ones on the rally cars iirc. cheers steve lll let you know. think ill just keep an eye out for 1 do you know of any others that worked well like the xj6? dan Quote Link to comment Share on other sites More sharing options...
84_S12 Posted October 24, 2008 Share Posted October 24, 2008 Get an ammeter and go through your fuse box terminals one by one just replacing each fuse with the meter till you get a reading Quote Link to comment Share on other sites More sharing options...
