esky 73 Posted August 7, 2008 Share Posted August 7, 2008 distance from cam angle sensor to rad support panel is180mm not to sure why some pics have come out different sizes, sorry Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 7, 2008 Share Posted August 7, 2008 Your radiator setup looks pretty weird lol. Pipewise for cooler thats exactly what I was thinking to do. How much from say, the front of CAS to the very front of that top radiator valence? Quote Link to comment Share on other sites More sharing options...
esky 73 Posted August 7, 2008 Share Posted August 7, 2008 yeah i will be changing the radiator/fan around shortly, i am putting a better rad in and swapping the fan to the engine side of rad, then moving the whole lot foward, i will have to modify the water outlet off the engine slightly to get better flow into rad, was in a bit of a rush to get it going again after the front conversion, the tape is against the cas bolt head, the top rad panel is the one i smoked in there from the other car, so it may be a couple of mill either way, but grill and everything lines up bang on so it must be fairly close Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 7, 2008 Share Posted August 7, 2008 Sweet cheers heaps fo that, I will compare to mine in weekend. As for rad, I want to buy one of the Civic alloy ones but want to know it will cool the engine first.. My guess is no as they are bloddy small, smaller than standard CA. Quote Link to comment Share on other sites More sharing options...
esky 73 Posted August 7, 2008 Share Posted August 7, 2008 i am not to sure what mine is out of but it seems to cope....just! the temp sits on 75 when tooling around but start to feed it the fat for a while and she creeps up, around 90-95, i think with the above mentioned changes it should be fine though, why the old owner put the fan in front i'm not sure, if this don't work out i will get a custom one made, i know on the drift cars i have built (nissans) you cant go past the dirty old engine fan and shroud, so maybe i will go that way, room may be a issue Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted November 14, 2008 Share Posted November 14, 2008 When i eventually get mine going, and get sick of it, ill... ..it, Cause thats manly. Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted January 15, 2009 Share Posted January 15, 2009 http://www.240sxforums.com/forums/ca18d ... t-faq.html Some interesting information, how to time, HUGE list of part numbers etc. Quote Link to comment Share on other sites More sharing options...
RT Posted January 15, 2009 Share Posted January 15, 2009 hey dan I thawt you were putting a rota in it au Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 15, 2009 Author Share Posted January 15, 2009 hey dan I thawt you were putting a rota in it au i am mate in my mk1 this topic is pretty old at one point i was going to put a ca18de in my wagon. but even thats gone now dan Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted January 20, 2009 Share Posted January 20, 2009 http://www.silviawa.com/forums/index.ph ... opic=27650 Some handy Genuine and Aftermarket part munbers. A CA forum index. http://forums.nicoclub.com/zeroforum/126 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 13, 2009 Author Share Posted May 13, 2009 still keen for some pics of peoples engine mounts. and what about the greab box mounts. cheers dan Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 14, 2009 Author Share Posted May 14, 2009 so to do this converstion i will need ca18det (flywheel,p,plate if it was auto) gearbox driveshaft loom,ecu radiator intercooler ,piping fuel pump return fuel line and make some engine , gearbox mounts anything im missing Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted May 14, 2009 Share Posted May 14, 2009 Electric fans or Factory one? Also what diff will you use? Flange needs modified to suit D/S. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 14, 2009 Author Share Posted May 14, 2009 Electric fans or Factory one?Also what diff will you use? Flange needs modified to suit D/S. ive got a electric fan im going to use an escort diff for now Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 14, 2009 Share Posted May 14, 2009 Is this for the van? noticed you were selling the full 2L conversion from it on TM Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 14, 2009 Author Share Posted May 14, 2009 Is this for the van? noticed you were selling the full 2L conversion from it on TM yeah the xa i was going to buy got sold yesterday for $4500 so fucked off. and i burnt out the wiring in my van last week so its sitting in my garge stripped down for a full re wire and now i have some money in my pocket im going to ca18det it and soend some cash on it lol Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 14, 2009 Share Posted May 14, 2009 Woah, woah, woah! No XA Coupe?! Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 14, 2009 Author Share Posted May 14, 2009 Woah, woah, woah!No XA Coupe?! na man so pissed off was getting it for $8500 and had till next month to get the cash half way there and he rings me yesterday to say that some dude walked off the street waved $4500 in his face and he took it. fucking p heads Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 14, 2009 Share Posted May 14, 2009 That fucking sucks man. My condolences. Quote Link to comment Share on other sites More sharing options...
