Gaz Posted May 24, 2008 Share Posted May 24, 2008 I did ask him if vavles hit engine when turned over and he said no. He has machined grooves in piton head to allow for the larger valves.. Sounds like it is done right and has been thought about by someone with at least a semi knowledge of what they are doing.. doesnt mean it is done right tho still Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 24, 2008 Share Posted May 24, 2008 Maybe. I've seen guys put releifs into pistons with a dremmel while the engine is in the car. Then sucked out the swarf with a vacuum cleaner. Worked I spose. I'm always dubious about built motors. If you don't know who slammed it together, Fuck knows what dodgy shit had been done. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted May 24, 2008 Share Posted May 24, 2008 DELETED Quote Link to comment Share on other sites More sharing options...
Raizer Posted May 25, 2008 Share Posted May 25, 2008 The shop is Gisborne Machinery and cycle world, and the machinist is named DaveI don't know about WDE_BDY but i wouldn't touch a car engine from that guy! Quote Link to comment Share on other sites More sharing options...
sholdowa Posted May 25, 2008 Author Share Posted May 25, 2008 tbh all I'd use is the crank and pistons, and rebalance the rods ( if they're easy to split off the pistons ) and pistons, and just maybe the head ( if it's unleaded and gp.1 valves I can't lose! ) but if you know him, then maybe I'll just steer clear!!! I really appreciate this feedback folks. Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 25, 2008 Share Posted May 25, 2008 ^^ you mean youll use everything except the block haha. Why not use the block aswell, its all setup for the pistons. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted May 25, 2008 Author Share Posted May 25, 2008 Well, I've got a 205 block here, and I'd prefer to use that ( given that I'm a fat bastard, the weight penalty won't make much of a difference ). What I sort of mean to say is that I'd take it apart, and recheck everything, rebalance etc, and build it up myself. Then I can only point the finger at myself. I'm a bit worried about the comments about 'weight added' though - this is sort of a different approach to the one I'd take! Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted May 25, 2008 Share Posted May 25, 2008 DELETED Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 25, 2008 Share Posted May 25, 2008 Ahh I see. I didnt look, is the one for sale not a 205 block? Also what is this adding weight? Quote Link to comment Share on other sites More sharing options...
sholdowa Posted May 25, 2008 Author Share Posted May 25, 2008 Ahh I see. I didnt look, is the one for sale not a 205 block?Also what is this adding weight? If you squint on one of the photos, then you can see a 20 in the casting. And the 205 block is stronger but heavier than the original block... Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 25, 2008 Share Posted May 25, 2008 Id still be tempted to buy. Offer him $600 and I reakon he will take it. Quote Link to comment Share on other sites More sharing options...
efp0wa Posted May 27, 2008 Share Posted May 27, 2008 http://www.burtonpower.com/ Quote Link to comment Share on other sites More sharing options...
peteretep Posted May 27, 2008 Share Posted May 27, 2008 http://www.burtontakesallyourmoneypower.com/ Quote Link to comment Share on other sites More sharing options...
efp0wa Posted May 27, 2008 Share Posted May 27, 2008 lol too true! Quote Link to comment Share on other sites More sharing options...
sholdowa Posted May 27, 2008 Author Share Posted May 27, 2008 http://www.burtontakesallyourmoneypower.com/And then there's the freight...I'll see if I can get those measurements sorted tomorrow for you testament... Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 27, 2008 Share Posted May 27, 2008 Buy this and save yourself HEAPS of $$$$http://www.trademe.co.nz/Browse/Listing ... =156657713 Will do 200hp with 45's a Vizzard head tickle and the right tune. I'd believe that when I saw the dyno run. Have a look here at the pinto leader board http://rs2000.mine.nu/forum/topic.asp?TOPIC_ID=10930 There's carbed, EFI, turbo'ed and supercharged. If you want 200 HP you really need to go forced induction unless you want to drive a race engine on the road. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 27, 2008 Share Posted May 27, 2008 and want to increase the capacity as far as poss without going silly money. I'm keeping it na, so want to keep the piston tops approx at the top of the ( 205 ) block - with the longest rods possible.Is there anywhere I can look this kind of stuff up on the net, or a local guru about??? There's a datson rod/ subbie combo that works, i have the details burried some where I'll see if I can find them. From memory its pricy as theres a bit of machining to get done. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 27, 2008 Share Posted May 27, 2008 <100hp/L - bored out to 2.2LBut still probably need revs >7500 It would need a stroker crank to get that. Can't really bore a pinto much over 2.1L. Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 27, 2008 Share Posted May 27, 2008 <100hp/L - bored out to 2.2LBut still probably need revs >7500 It would need a stroker crank to get that. Can't really bore a pinto much over 2.1L. It has been stroked. Reground Camshaft (nice and lumpy) High pressure valve springs Stanless steel valves (bigger and lightened) Port and polish Planed head Bored out to 2.2L Over sized pistons (from Subaru) Longer rods (from Toyota) Stroked and balanced crank Rebuilt oil pump But yeah its sold now for $700. I think a good idea even if its a gamble. Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 27, 2008 Share Posted May 27, 2008 I'd believe that when I saw the dyno run. Have a look here at the pinto leader board http://rs2000.mine.nu/forum/topic.asp?TOPIC_ID=10930 There's carbed, EFI, turbo'ed and supercharged. If you want 200 HP you really need to go forced induction unless you want to drive a race engine on the road. Yeah perhaps your right. I was talking at the fly tho which is around 140 at the wheels. When ya take away 30% drivetrain loss thats 104.398kw@wheels. 2 of the NA cars in your list have that and a few more are close to. But yeah your prob right, it would prob be quite a cunt on the street. Id do it more for the torque advantage or as a start for a tourqey turbo setup. Added the ist as its quite good as a reference regaurdless.Would be good if we knew what was done to each engine. Are they all 2l or 1600? I notice it says RS2000 in places but just Mk2 in others. 1. Nathan Chapman - Turbocharged Mk1 Escort - 180.9kW 2. Kurt Harmer - Turbocharged Mk2 Escort - 147.1kW 3. Jon Tarr - Turbocharged Mk2 Capri - 132.7kW 4. Danny Mischok - N/A MK2 Escort - 115.6kW 5. Doug - N/A MK2 RS2000 - 96.2kW 6. Ben Shields - Supercharged MK1 Escort - 95.7kW 7. Glenn Slender - N/A MK2 RS2000 - 94.0kW 8. Sean Stewart - N/A MK2 RS2000 - 86.7kW 9. Rhys Munro - N/A Mk2 Escort - 85.9kW 10. Rusell Munro - N/A MK2 RS2000 - 83.1kW 11. Glenn Evans - N/A MK1 Escort - 81.1kW 12. Steve Pfeiffer - N/A Mk2 RS2000 - 80.3kW 13. James Rudd - N/A Mk2 RS2000 - 78.0kW 14. Callum - N/A Mk2 Escort - 77.9kW 15. Rhys Hillman - N/A Mk2 RS2000 - 75.4kW 16. Michael (Mr Mk2) - N/A 1.6L Pinto Mk2 Escort - 75.3kW 17. Reece Gomba - N/A Mk2 RS2000 - 74.1kW 18. Simon (nismo_capri) - N/A Mk1 Escort - 69.92kW 19. Avon McIntyre - N/A Mk2 RS2000 - 66.1kW 20. Jason O'Halloran - N/A Mk1 Cortina - 59.6kW 21. STOCK STANDARD - MK2 Escort - 49.0kW = 85hp flywheel APROX Quote Link to comment Share on other sites More sharing options...
