Austin Princess 4 pots on Escort
eskynut
^^ Yeah worth it hard performance wise. Used to be worth it hard price wise also.. They are not cheap nowdays tho.
If your semi handy you could go the Volvo option. They are cheap as chips and pretty easy to make work. Think one hole needs slight slotting. The only part that really makes it harder is that you'll need to make your own spacer kit up rather than buy one.
Spacer kit can be brought from http://www.palmside.co.nz for the AP calipers.
and if you go volvo i haz teh contacts for calipers
Hook a brother up please..
Both holes need slotting, and if you get calipers off a Volvo 200 series (the common ones) you don't need spacers
//oldschool.co.nz/phpbb/viewtopic.php?t=9053
  • 1 year later...
Yo currently doing brake conversion. Pretty easy if you have patience and a small round file.
I think the ideal volvo callipers to go for are the girling ones used with vented discs. If I remember right you don't need spacers for em if you get the vented ones.
I'm using the vented ATE ones but am having a hard time finding seal kits etc for them.
Excuse my ignorance/slightly ot but regarding the twin>single feed, why cant you just plumb a "T" section in - the same way rear brake lines are often done, but to each caliper rather than each wheel (ie so two "T" sections - one for the right caliper, one for the left)
This is an option
And this is an option
i've got twin line 4 pots that have been drilled through (spacer too) to run single line, is this an option
But the earlier mentioned is the cheapest to do.
Gaz
