Mr dori Posted October 27, 2007 Share Posted October 27, 2007 My 1uz dosnt wana move, Im gana put wd40 down the bores to try free it up, have you guys got any ideas> Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted October 27, 2007 Share Posted October 27, 2007 you can put a bit of oil down the bores. Let it sit in there and run through for a while. Gently crank over by hand. Quote Link to comment Share on other sites More sharing options...
Hemi Posted October 28, 2007 Share Posted October 28, 2007 ...get a bigger starter Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 28, 2007 Share Posted October 28, 2007 Umm, would any water be down the bores somewhow? Moisture? If it has rusted enough to seize it then I would rip head off and have a look, turning it over with rust might scratch up the bores alot more than ripping the pistons out. Quote Link to comment Share on other sites More sharing options...
Mr dori Posted October 28, 2007 Author Share Posted October 28, 2007 i really dont know aye,fukn thing wont budge at all, its slutting me pretty hard aye, the wreker doesnt want a bar of it aye Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 28, 2007 Share Posted October 28, 2007 Wont move either way? Were the plugs in and manifolds on it while its been sitting? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted October 28, 2007 Share Posted October 28, 2007 Doesnt sound to good. Try filling it with diesel and let it soak for a bit. Was told this is a good way to store engines as well. Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 28, 2007 Share Posted October 28, 2007 if my motor has been sitting for a year with oil in it, and it still turns over freely(gets harder on compression as expected), is it ok? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted October 28, 2007 Share Posted October 28, 2007 Yep, throw some oil in the spark plug 'oles when you turn it over. just keeps it from corroding. Quote Link to comment Share on other sites More sharing options...
Mr dori Posted October 28, 2007 Author Share Posted October 28, 2007 got a big bar on it and cranking with starter, seems to be moving ever so slightly, hopefully shes gana be sweet Quote Link to comment Share on other sites More sharing options...
kpr Posted October 28, 2007 Share Posted October 28, 2007 maybe worth sliding the gearbox off just to check it it isnt a clutch/bellhousing issue ? Quote Link to comment Share on other sites More sharing options...
Mr dori Posted October 28, 2007 Author Share Posted October 28, 2007 yea could do aye, pretty confident its not but yea might pay to Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 28, 2007 Share Posted October 28, 2007 hay man doesnt sound to good i had a 2lt ford motor that was stuck soild took the head and all the pistons were down abit (none at TDC) and my old man told me to fill the bores from the pistons up with coke and leave it till its all gone get a big bar on the crank and turn it over and that worked. so if all esle fails try coke dan Quote Link to comment Share on other sites More sharing options...
Guest sexychevette Posted October 29, 2007 Share Posted October 29, 2007 my southafrican friend fixs everyuthing with coke. its so funny. 'oh no my clutch is sliping!' him='have you got any coke' works tho Quote Link to comment Share on other sites More sharing options...
sholdowa Posted October 29, 2007 Share Posted October 29, 2007 my southafrican friend fixs everyuthing with coke. its so funny. 'oh no my clutch is sliping!' him='have you got any coke'works tho It's got to be flat coke to fix a clutch And yes, it really does work. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted October 29, 2007 Share Posted October 29, 2007 How do you apply said coke to the clutch? take starter out? Quote Link to comment Share on other sites More sharing options...
Guest sexychevette Posted October 29, 2007 Share Posted October 29, 2007 was on a bike...my uncle used it on his econovan also i heard mountain dew is even better Quote Link to comment Share on other sites More sharing options...
sholdowa Posted October 29, 2007 Share Posted October 29, 2007 How do you apply said coke to the clutch? take starter out? Chuck it through the hole in the bellhousing where the release arm comes out. Works on escorts... Quote Link to comment Share on other sites More sharing options...
