sentra Posted July 25, 2007 Share Posted July 25, 2007 put lumps of steel in and never look back Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 26, 2007 Share Posted July 26, 2007 because those ford ones are puss and skiddings hard on the mounts people rip those big ass toyota ones to bits, but sounds like your going the right was about it now Quote Link to comment Share on other sites More sharing options...
Mr dori Posted July 26, 2007 Author Share Posted July 26, 2007 got some ford ones today, i need 12mm studs not 10mm, that ws silly wasnt it!!!! What about solid ally bushes? ive seen i !uz rev with a coin on the top and it didnt move, wonder if theyd be savage or not!? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 26, 2007 Share Posted July 26, 2007 What about getting your old mounts re made using Nolathane? Too weak? Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted July 26, 2007 Share Posted July 26, 2007 What about solid ally bushes? ive seen i !uz rev with a coin on the top and it didnt move, wonder if theyd be savage or not!? Just remember, gotta do gearbox mount solid too if you solid mount the engine. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 26, 2007 Share Posted July 26, 2007 What about solid ally bushes? ive seen i !uz rev with a coin on the top and it didnt move, wonder if theyd be savage or not!? seen a JZ with a coin on top to smooth as fuck but still rips the mounts when doing skids. Edit: oh an unclejake its custom mounts to get th v8 in his soarer so there is no factory mounts realy but urethane mount would be the go Quote Link to comment Share on other sites More sharing options...
Mr dori Posted July 26, 2007 Author Share Posted July 26, 2007 ah fuk it im confused now, non of the mounts ive seen have a 12mm stud, fukn should make the brackets to go the the std crossmember mounts aye!!!!! Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 26, 2007 Share Posted July 26, 2007 fuck just do whatever then work from there. Your trying to convert it so it sits on the newer style vertical mounts that later toyotas have aye? just seen most guys with that style go solid in the end when doing skids Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted July 26, 2007 Share Posted July 26, 2007 landrover ones use 3/8 unf thread. we use them on all the 1uz's. real stiff. Quote Link to comment Share on other sites More sharing options...
Mr dori Posted July 26, 2007 Author Share Posted July 26, 2007 got a pic boes Yea ive already hacked the old angle mounts off member, trying to go to vertical style like you said bro. Cant really be fuck mount gbox sold aswell, i d have to for a cert thio aye? certs are over rated! Quote Link to comment Share on other sites More sharing options...
Mr dori Posted July 26, 2007 Author Share Posted July 26, 2007 Kinda what im on about Factory stz, thats to thick Quote Link to comment Share on other sites More sharing options...
sentra Posted July 26, 2007 Share Posted July 26, 2007 noone will ever know if you leave the gbox mount rubber, it makes the car 100% more pleasant then having all mounts solid. (not technically legal but will go over cert, vtnz. 100% safe. anyone saying otherwise hasnt done it.) benifits include no exhaust flexi joint needed, minimal exhaust/body clearances, solid exhaust hangers mean you can drop the gearbox and the motor doesnt need supporting, etc. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 26, 2007 Share Posted July 26, 2007 benifits include no exhaust flexi joint needed, minimal exhaust/body clearances, solid exhaust hangers mean you can drop the gearbox and the motor doesnt need supporting, etc. dude unless your fwd who runs a flexi joint?? Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 26, 2007 Share Posted July 26, 2007 benifits include no exhaust flexi joint needed, minimal exhaust/body clearances, solid exhaust hangers mean you can drop the gearbox and the motor doesnt need supporting, etc. dude unless your fwd who runs a flexi joint?? Subaru Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 26, 2007 Share Posted July 26, 2007 I have been told that solid mounted motor = stuff falls off car due to vibration transmitted into shell rattling everything loose. I haven't tried it myself though. Quote Link to comment Share on other sites More sharing options...
Bistro Posted July 27, 2007 Share Posted July 27, 2007 I have been told that solid mounted motor = stuff falls off car due to vibration transmitted into shell rattling everything loose.I haven't tried it myself though. yah yah, heard that too. pretty obvious though. i mean check somehting like this , could you imagine if that was full solid mount....fuck that shit. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted July 27, 2007 Share Posted July 27, 2007 DELETED Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 27, 2007 Share Posted July 27, 2007 yup UZ is pretty smoth dont think you'd notice guy of garage doris mounts Quote Link to comment Share on other sites More sharing options...
sentra Posted July 27, 2007 Share Posted July 27, 2007 dude unless your fwd who runs a flexi joint?? i needed to quickly add some substance to my benifits list, it was the first one that came to mind mines a ported rotary, the only real diffirece was the dash got a bit rattlyer. compared to the hard suspension/spherical bearing strut tops etc your likely to be using in a car that does such cranking skids that it tears mount rubbers its un noticible. does that garage dori one have a rubber/lolathane isolator or 'just' a rod end? 1 Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 27, 2007 Share Posted July 27, 2007 Mounting an engine on a spherical bearing (rose joint) seems like a waste of a bearing. I can't quite see the logic in locating the engine with something that is designed to move but can't because of the way it is being used. Did I miss something?. Edit - I guess it would be good to allow for errors in the mount fabrication that result in the mounts not aligning to the crossmember Quote Link to comment Share on other sites More sharing options...
