Guest 4age_starlet Posted April 2, 2007 Share Posted April 2, 2007 im about to recover my doors cards in black vinyl could anyone tell me what kinda glue to use? Quote Link to comment Share on other sites More sharing options...
davidian Posted April 2, 2007 Share Posted April 2, 2007 you can use staples if the card is thicker Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted April 2, 2007 Share Posted April 2, 2007 yep but i still need to use glue to Quote Link to comment Share on other sites More sharing options...
Toucan Posted April 2, 2007 Share Posted April 2, 2007 Ados I think its called, its good stuff Quote Link to comment Share on other sites More sharing options...
lowlancer Posted April 2, 2007 Share Posted April 2, 2007 I used the spray on stuff from super cheap, worked a treat Quote Link to comment Share on other sites More sharing options...
Mike-e Posted April 2, 2007 Share Posted April 2, 2007 Ados I think its called, its good stuff FTW Quote Link to comment Share on other sites More sharing options...
Snoozin Posted April 3, 2007 Share Posted April 3, 2007 I've had issues using the Ados F2 spray adhesive to hold fabric backed vinly onto MDF. It won't quite stick properly in heat. Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted April 3, 2007 Share Posted April 3, 2007 my plan was to use glue and then heat up the vinyl with heat gun strech it over and staple it Quote Link to comment Share on other sites More sharing options...
Snoozin Posted April 3, 2007 Share Posted April 3, 2007 For added effect, put a thin layer of foam between the vinyl and the door card, like 3mm odd. Makes it that much nicer! Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 3, 2007 Share Posted April 3, 2007 meant to be doint this to thmini while its away, ados F2 paste stuff is mint, used it on my dash, just get yourself organised and you'll be sweet Quote Link to comment Share on other sites More sharing options...
htwn-escort-boy Posted April 3, 2007 Share Posted April 3, 2007 ^^ yup that makes it look so much better, gives a better flatter finish, and then yeah ados is fuckin grouse shit Quote Link to comment Share on other sites More sharing options...
Ke36 Posted April 3, 2007 Share Posted April 3, 2007 as others have said put a thin layer of foam underneath it spray-on glue that to the card then spray-on glue ontop of that to stick the fabric on then use either staples or hot glue on the back to secure it Quote Link to comment Share on other sites More sharing options...
Snoozin Posted April 3, 2007 Share Posted April 3, 2007 meant to be doint this to thmini while its away, ados F2 paste stuff is mint, used it on my dash, just get yourself organised and you'll be sweet Yuh the Ados paste is way more ftw than the spray in my experience. Quote Link to comment Share on other sites More sharing options...
