Burntrubber Posted March 26, 2007 Share Posted March 26, 2007 Gasless wire is sweet on stuff over 2mm especially if its galvanized. Its not the best on panel steel but someone whos good with it can do it. We use it all the time where I work like 10 5kg rolls a month. Its also very expensive about $100 for a 5kg roll. Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2007 Share Posted March 26, 2007 So where can i get disposable bottles of gas? I don't have the $ to rent off BOC atm Quote Link to comment Share on other sites More sharing options...
Mike-e Posted March 26, 2007 Share Posted March 26, 2007 my experience with disposible bottles is shit. cant remember where i got the bottle from. but they hold a reasonable amount of *insert inert gas here* problem is they dont seal for shit. used once, used fuckall, leaked rest of gas. fuckin gaybar. the way is to get your own bottle (i bought mine stolen recovered from nz police) scratch all the shit off/ paint it, make a sticker "HellRaizer Engineering" and get it filled. every 10 yrs or so you have to get it tested also. works out heaps cheaper than renting if you dont use very much gas/handyman stz Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2007 Share Posted March 26, 2007 Haha sweet, i think i know where an old acetylene bottle is too Quote Link to comment Share on other sites More sharing options...
Mike-e Posted March 26, 2007 Share Posted March 26, 2007 old acetylene bottle wouldnt be sweet boes, as theyre filled with porus spongy shit and acetone need a c02 bottle or argon or whatever Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2007 Share Posted March 26, 2007 Wonder if a big fire extinguisher would be all good? Quote Link to comment Share on other sites More sharing options...
Mike-e Posted March 26, 2007 Share Posted March 26, 2007 C02 one could probably work, with a regulator adapted it Quote Link to comment Share on other sites More sharing options...
corrupt Posted March 26, 2007 Share Posted March 26, 2007 so whats better, arc or gasless mig? Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2007 Share Posted March 26, 2007 so whats better, arc or gasless mig?Gasless mig! Iv got gasless mig atm, its shit but its still alot better than my old arc! -depends what your doing though, the arc's better on heavy stuff to me anyway Quote Link to comment Share on other sites More sharing options...
Mike-e Posted March 26, 2007 Share Posted March 26, 2007 both are shit IMO avoid avoid avoid etc but i suck at both. proper mig/tig/acetylene ftw Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 26, 2007 Share Posted March 26, 2007 both are shit IMO avoid avoid avoid etcbut i suck at both. proper mig/tig ftw, acetylene FTMFW! Quote Link to comment Share on other sites More sharing options...
corrupt Posted March 26, 2007 Share Posted March 26, 2007 the only problem i find with my arc would be blowing holes. other than that if you get it to penetrate well its fine imho with a bit of grinding/tidying up afterwards Quote Link to comment Share on other sites More sharing options...
Lunacy Posted March 26, 2007 Share Posted March 26, 2007 Definitely get a mig for wat ur doing, as it is quite easy to pick up as a noob. I just started welding this year, and have nearly finished my exhaust for the staz and havnt had any major probs at all. If ur super keen theres a couple of good books i saw at the library on techniques and stuff too. My 2c Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 27, 2007 Share Posted March 27, 2007 So where can i get disposable bottles of gas? I don't have the $ to rent off BOC atm The toolshed sells em and i think i heard someone say mitre ten also has them. cost something like 35 bucks and that will give you about 40 min welding time. Quote Link to comment Share on other sites More sharing options...
yelo76 Posted March 27, 2007 Share Posted March 27, 2007 Well, may as well through in my 2c as well. Note I am not a professional at this. I have spent the last year teaching myself to weld, I bought a $450 mig off trademe (Pioneer, made by Telwin, but their cheep brand). It only has a max and min setting. It has taken some practice but I am sucessfully welding down to 0.6 panel steel without too much problem. You need to have a minimal gap between joins or it can blow holes that you need to fix up, just take the time to get it fitting right first and you will be OK It is a gasless mig, so yea it does splatter a bit, seems to be better if the tip is closer to the metal. Most of it comes off with a wire brush, and if you want a better finish the grinder with a flapper wheel works wonders. I have also bought a autodarkening helmet of trademe, I don't seem to have any issues with it being slow to respond, but I guess I don't use it for large amounts of time so wouldn't notice the effects as much. See my thread on the car for some results Quote Link to comment Share on other sites More sharing options...
Mike-e Posted March 27, 2007 Share Posted March 27, 2007 http://www.mig-welding.co.uk/welding-gas.htm ^ aws link. do your bottles up properly, bleed your lines, dont leave regulators done up and use a spark arrestor other wise your navara is going to get fucked up. Incident Description * This incident happened on Monday the 29th of September 2003. A fitter with a work van left an E size Oxygen and Acetylene cylinder on the back seat of a Toyota dual cab over the weekend. The Acetylene cylinder valve was not fully closed and a leak occurred. * Over the weekend the Acetylene accumulated in the van. On Monday morning the fitter approached the van and opened the door, a large explosion took place. The ignition may have been caused by either the internal light circuitry, the automatic door control, mobile phone which was on the front seat of the van, or lighting a cigarette. The fitter was also a smoker. He has damage to his ear drums and facial damage Quote Link to comment Share on other sites More sharing options...
blakamin Posted March 27, 2007 Share Posted March 27, 2007 acetylene will explode without ignition if not under pressure with certain things won't it? (just tryin to remember)??? Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted March 27, 2007 Share Posted March 27, 2007 Wonder if a big fire extinguisher would be all good? Yep, they are. I forget the crowd who puts the regulator on, but itworks out bloody cheap. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 27, 2007 Share Posted March 27, 2007 acetylene will explode without ignition if not under pressure with certain things won't it? (just tryin to remember)??? oil etc and acetylene = bad mix Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted March 27, 2007 Share Posted March 27, 2007 acetylene will explode without ignition if not under pressure with certain things won't it? (just tryin to remember)??? Don't think so but it will explode if compressed to more than 15psi. Quote Link to comment Share on other sites More sharing options...
