d.p.n.s Posted October 15, 2006 Share Posted October 15, 2006 ive got a spear ford 2lt head and the guy i got it of said it had a mild race cam in it how do i check on this. cheers Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted October 15, 2006 Share Posted October 15, 2006 Edit: just re read that, try look for a casting number maybe?, compare it to a standard cam or put it on your engine and find out Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 15, 2006 Author Share Posted October 15, 2006 cheers man found the number its a bit fuked to read has anyone got a stander cam to let me know what the number is .cheers Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted October 15, 2006 Share Posted October 15, 2006 Only way you can accuratley tell is to put it on and engine and turn it over and measure the timing with a degree wheel. A camshaft shop will be able to tell you as well. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 15, 2006 Author Share Posted October 15, 2006 cheers mate Quote Link to comment Share on other sites More sharing options...
cubastreet Posted October 15, 2006 Share Posted October 15, 2006 A race cam will prolly be higher lift, can measure that with micrometer. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 15, 2006 Share Posted October 15, 2006 Buy a dial guage and measure the lobes. Then measure a standard ones lobes. Quote Link to comment Share on other sites More sharing options...
RT Posted October 15, 2006 Share Posted October 15, 2006 it's probably just a re-grind... so if it is you'll find lash caps on the rocker gear. Or else its very mild.. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 16, 2006 Share Posted October 16, 2006 ^^ not many people I have talked to even know what lash caps are.... Quote Link to comment Share on other sites More sharing options...
Rusted Posted October 16, 2006 Share Posted October 16, 2006 A race cam will prolly be higher lift, can measure that with micrometer. Could also be a longer valve opening time, Wider to Taller. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 16, 2006 Share Posted October 16, 2006 ^^^ duration you mean Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted October 16, 2006 Share Posted October 16, 2006 Sorry to hijack thread, but lash caps are the little caps that sit on top of the valve, in the middle of the spring ay?, Not exactly sure what they do, can someone explain? when you re-grind a cam it obviously makes the lobes smaller so lash caps make up for this loss. What they are all depends on the engine.. on my falcon they are just wee washes that go on the roller rocker posts.. on a pinto they are little caps that sit on top of the valves to lift the rocker get it? Quote Link to comment Share on other sites More sharing options...
Rusted Posted October 16, 2006 Share Posted October 16, 2006 Yeap! Increased duration. Cheers Methz Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 16, 2006 Share Posted October 16, 2006 Sorry to hijack thread, but lash caps are the little caps that sit on top of the valve, in the middle of the spring ay?, Not exactly sure what they do, can someone explain? Yeap. lash cap sits on end of valve. They allow you to adjust the rocker ball correctly. If you dont have them, to get the cam contact right they need to be wound right up. This will loose lift from the cam. Alot of aftermarket cams will be reduced as people dont use lash caps and adjust the ball way up. This will be diff for diff engines/heads by the way. not all heads use them. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted October 16, 2006 Share Posted October 16, 2006 Cheers man, good explanation Quote Link to comment Share on other sites More sharing options...
