peteretep Posted August 22, 2006 Share Posted August 22, 2006 how do you think I should go about stopping fuel going everywhere, I am changing to an electric fuel pump which will be mounted near the tank (at rear), tank is about 1/4 full and line is just metal Quote Link to comment Share on other sites More sharing options...
zep Posted August 22, 2006 Share Posted August 22, 2006 I dunno where you get them, but I have a hose blocker. it goes around the hose and you scew it up, pushing the hose together and blocking it up. Some kind of chemistry item I think... Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 22, 2006 Author Share Posted August 22, 2006 yeah I was thinking maybe silicone or something to go in there until I get onto emptying the tank Quote Link to comment Share on other sites More sharing options...
Toucan Posted August 22, 2006 Share Posted August 22, 2006 Syphon it into the Gaylant? Blocking the rubber ones are easy, wooden dowel or something in them, not sure about the tank end of things, I drained it into a jerry can Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 22, 2006 Share Posted August 22, 2006 Wind a bolt down the rubber then use a circle clip and wind it tight around the base of the bolt. Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted August 22, 2006 Share Posted August 22, 2006 just use a punch that fits inside, works great Quote Link to comment Share on other sites More sharing options...
crazy_rich Posted August 22, 2006 Share Posted August 22, 2006 Wind a bolt down the rubber then use a circle clip and wind it tight around the base of the bolt. do that. or just fold the hose over its self and ziptie it off. or do what i did when i pulled the crapper apart, park the ride on next to it, hose in the tank and let gravity do its thing Quote Link to comment Share on other sites More sharing options...
thminiman Posted August 22, 2006 Share Posted August 22, 2006 the pipes metal, methodz idea will work, alternatively, try and find a little bit of rubber pipe and block one end of that with a bolt and hose clip, then put that onto the pipe on your car and hose clip that on. you should be able to find a good diameter pipe on the engine youve just taken out dunno if that made sense to other people, but made sense to me Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 22, 2006 Author Share Posted August 22, 2006 ok i might try putting some rubber on it and clamp it with a bolt in it Quote Link to comment Share on other sites More sharing options...
danger Posted August 22, 2006 Share Posted August 22, 2006 Nah best thing I've ever found is just those little plastic faber-castell or similar felt tip pen lids, The wee white caps from the little colourful felt pens that all little kids seem to have. Work a charm and you can block anything from about 6mm tubing up to 8mm tubing. Quote Link to comment Share on other sites More sharing options...
