thmini's mini
davidian
  • Replies 266
Nah thats probably worse than thrashing it. Run it hard to about 4500/5k tops through gears, this pushes the rings hard against the walls and lets them seal properly, then let it decelerate which makes a vacuum to suck all the crap off the bores. For first start get oil pressure then let it run at 2500ish for about 15 minutes (make sure it doesn't over heat) to run the cam in. Roughly tune the carbs while its running, but try not to let it idle as it will fuck your cam especially if your running a big cam/uprated valve springs
After that try not to let it idle too long, just to tune carbs properly etc.. try do this after you've done a few Ks
Cheers boe for slaves, squirted brake fluid into my eye ftl/lols
/\bump so tom reads previous post,
also i just baught a brand new 4 core rad, tuff
got my new cylinder head/heads also, looks like one of them has new exhaust valves = might be good, might be bad, will see tommorow when i get the valves out to see what the seat is like
