Ogre Posted June 19, 2005 Share Posted June 19, 2005 //oldschool.co.nz/index.php?/topic/18286-ogres-1981-ex-lancer/?p=479061 So what you guys think? Ive only just really started "doing it up" Still got alot of things i want to do to it. Quote Link to comment Share on other sites More sharing options...
durty Posted June 19, 2005 Share Posted June 19, 2005 i like the sound of ur future mods. specially dished 15s. mmmmmm Quote Link to comment Share on other sites More sharing options...
Defcon Posted June 19, 2005 Share Posted June 19, 2005 How come you didnt go the dohc 4g63 route? Any particular reason- doesnt work with rwd?? Just interested. Def' Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 19, 2005 Share Posted June 19, 2005 The sohc goes directly in. It's seriously the easiest conversion ever. I heard the guy who owns this car is gay Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 19, 2005 Share Posted June 19, 2005 hahaha, awesome Quote Link to comment Share on other sites More sharing options...
Ogre Posted June 19, 2005 Author Share Posted June 19, 2005 man lowlancer, you need to grow up.You just wish i was gay so you could get some of my well known, good lovin. I never went the DOHC coz it means alot more work, and if you do that you might as well slap a vr4 in there witch is what im gonna eventurly do. Ive found this to be an extremely easy conversion, but its taken alot of resourch and time to figure out what bits you can shoehorn in there. End result was all good tho. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 19, 2005 Share Posted June 19, 2005 Same plan as myself y0 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2005 Share Posted June 20, 2005 would be the shit.200hp at the wheels at least.And thats standard!!. Ive removed all the sound deadening from the under the back seats and boot 2day.Damn that shits HEAVY!! Suprised actually Quote Link to comment Share on other sites More sharing options...
Defcon Posted June 20, 2005 Share Posted June 20, 2005 200hp from a standard sohc 2ltr at the wheels, u must be joking? If thats correct it will go like the clappers! The gem had bugger all sound deadening, doesnt have much toelse to rip out either....thats stuff sucks to pull out! Quote Link to comment Share on other sites More sharing options...
zep Posted June 20, 2005 Share Posted June 20, 2005 They're talkin about the vr4 engine, I think Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted June 20, 2005 Share Posted June 20, 2005 8g vr4 engine is 280hp Quote Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2005 Share Posted June 20, 2005 well to be exact, wat i want to do it.......... Starion 4g63bt block vr4 pistons and rods vr4 head, intake, turbo etc link computer. Reason for using a starion block is that its easy to bolt a gearbox up.In fact the gearbox i have now will bolt straight up and the d50 tranny is sposed to be good for up to 400hp.so there ya go. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 20, 2005 Share Posted June 20, 2005 log in pus nuts....... turn's on, why dont 4g63BT's from vr4's bolt up? apparently 2.5 turbo diesel boxes are the ones to use in vans, should be easy as pie to get an l200 box so you have floor change, then mac a vr4 engine in front of that.. easy. water pipes are next hardest part, which shouldnt be too bad Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted June 20, 2005 Share Posted June 20, 2005 there is a van up here with a vr4 in it.. goes fuken nuts Quote Link to comment Share on other sites More sharing options...
Ogre Posted June 20, 2005 Author Share Posted June 20, 2005 well i dont know.Thats what everyone does. You sure the deisel box bolts straight up? Come to think of it i have heard somone say somthing about that b4 actually.Are they cable clutch or hydrolic? The box would bolt up fine and could just use the extention housing off a sigma or l200 box. hmmmm Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 20, 2005 Share Posted June 20, 2005 hydraulic, although you wouldnt be able to use it due to the column change aspect.... l200s with 4d52's in them are common as mud, shouldbnt be hard to get a gearbox at all..... turbo or not,m they should be the same. you wouylda heard it from me a couple years back when i was looking at that van that rob from 1st automotive had as a workshop hack - bert at mike murphy has it now... mean bit of gear, would be the first one done in nz i would expect, it's been around for at least 4 years. rob told me that all you need is a 2.5 turbo box, and he used an evo 5 flywheel and clutch assy. again, the non turbo box is probably the same, might have different ratios or something - mine does 3200rpm at 100, not sure on the diff ratio though Quote Link to comment Share on other sites More sharing options...
Ogre Posted June 20, 2005 Author Share Posted June 20, 2005 well thats about that i do at 100k as well. i didnt know that l200s had 4g52s in them, thort they all 4g63 or 4g54. The box i have now is the same as the l200 box.Same length etc, so i guess that would work fine. Mybe the reason all the guys use the starion block is so it bolts up to the starion gearbox, or the lancer 1800GSR box, as thats the conversion most of them do. Quote Link to comment Share on other sites More sharing options...
Defective Posted June 20, 2005 Share Posted June 20, 2005 vr4 conversion is full of headaches..... you need to modify nearly everything... if ya want a starion block i have one, its smoky but id say its rings and turbo gone kaput. (theres like 4mm of freeplay in the turbo shaft) i have heaps of starion bits... ideal if ya wanna shoehorn the starion brakes and everything onto the front.... Quote Link to comment Share on other sites More sharing options...
Ogre Posted June 20, 2005 Author Share Posted June 20, 2005 well if you told me that a week ago i would have brought the bits off you!! but ive just got some GSR stuff off trademe Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 20, 2005 Share Posted June 20, 2005 well thats about that i do at 100k as well.i didnt know that l200s had 4g52s in them, thort they all 4g63 or 4g54. The box i have now is the same as the l200 box.Same length etc, so i guess that would work fine. Mybe the reason all the guys use the starion block is so it bolts up to the starion gearbox, or the lancer 1800GSR box, as thats the conversion most of them do. 4D52 dude - diesel.... thats what I;m told anyways..... google is yuor friend oviously, to delve into it further. Quote Link to comment Share on other sites More sharing options...
