FWD Engines into mk2 escort
Guest Demonmk2
  • Replies 64
I have no idea about this.
[urban legend?]
All I have heard is that honda engines, such as those, spin the oppoiste way or something, giving this 5 reverse gears and 1 fowards gear. I have no idea how much bullshit that is or what not, but it sounds funny and I wouldn't be surprised if it was true.
[/urban legend?]
Yes this is true.
I have a mate that reserched one. He was going to use a hilman avenger? diff from memory because you can reverse something to make it A ok. cant remember full story try googling it...
Also the s2000 box will not bolt up to a b16a. :( ratshit for that idea. looks like custom box for you. more dollars.....
Its a very expensive conversion jus for a bit of vtec. lol
dude needs to get real
it'd be way cheaper to go and get a 302, celica 5speed, front suspension from hell, extractors-no exhaust, mate them together and go wreak absolute havok around the place.
I'd rather sandblast all my skin off....
Formula Atlantic 4age pwns you :twisted:
.. yeah well, its still not a shitter small vtec, so whatever tickles your fancy
There is the odd honda person on here, we just keep quiet about it due to the completely incorrect biased views held by many people on this board.
Youve came to the correct conclusion, albeit for slightly the wrong reasons
As said above they are still mounted the same way as most other FWD motors they just spin the opposite direction.
The F20C from the S2000 spins the normal direction however so even if you could mount the B16A to it, it would still do you no more good than using a regular RWD gearbox from a supra or whatever.
I know plenty of people who have looked into it and I dont know anyone who has even got to the point of trying to build one, let alone actually making it work.
No factory honda motors have 135hp either. The ZC which is the 1.6 DOHC motor makes 130hp in its top black top form and less in the gold top. The B16A DOHC VTEC makes 160 in NZ New or EF civic/CRX/DA Teg or 170 in EGCivic/CRX/EKcivic form.
You shoudnt be anti a Honda owner, you never know what they have in their garage :wink:
Guest Demonmk2
by the way it ant v-tec its a zc engine yeha sorry it is 130hp read it wrong and 130hp is pretty decent for a n/a car, so what ur really saying about the opposite direction thing is that it cant be done and ill end up with 5 reverse gears?
you sure its even a black top? all i can say if you know nothing about the conversion and your trying to jump headfirst into it.. just work the kent or get a pinto.. if funds are a bit higher a nissan twincam would be good..
Even an old Nissan L or Z-series. It's a bit different. :)
Guest Demonmk2
it isnt a waste of time because im learning, that means if the hole engine is back to frontthe crank shaft and cylinders fire in the complete opposite order/direction? if anybody knows about the engine and how they run please tell me
nzhondas.co.nz :P
Nah just jankin ya... google it man, very popular engine and no doubt you can find out everything you want to know about it off the net
Guest Demonmk2
i was just wondering are all hondas anti-clockwise? or is it jsu tthe v-tecs cause if it is jsut v-tecs then im in luck :D
This topic is now closed to further replies.
