Guest Testament Posted March 21, 2013 Share Posted March 21, 2013 its its really obvious they are different to standard? or would he have to know what the standard ones looked like to know they are different? It doesn't really help but I think you would be very unlucky to get pulled up on that. Quote Link to comment Share on other sites More sharing options...
Guest cletus Posted March 21, 2013 Share Posted March 21, 2013 i wouldnt worry about it too much if the new saddles look like they could be factory. you can buy aftermarket swaybar links for things like commodores which have silly factory ones and they are not an issue Quote Link to comment Share on other sites More sharing options...
Guest Styles Posted March 21, 2013 Share Posted March 21, 2013 Cheers, they're a pretty ordinary saddle, just a little larger, that's all. Sounds like it'll be sweet, as long as I don't come across some total nazi. Cheers! Quote Link to comment Share on other sites More sharing options...
Guest k-trips Posted March 21, 2013 Share Posted March 21, 2013 Clint - 2 piece driveshafts - ala my Commy - 2 driveshaft loops required? Quote Link to comment Share on other sites More sharing options...
Guest cletus Posted March 21, 2013 Share Posted March 21, 2013 Yes, you will need 2. going to a single piece shaft doesnt really work either as far as a means to do just 1, floor rubbage will ensue. Quote Link to comment Share on other sites More sharing options...
Guest k-trips Posted March 21, 2013 Share Posted March 21, 2013 Nah I'm sticking with 2 piece driveshaft - will need 2 loops - I can obviously get away with a smaller loop on the front half about half way along you reckon? How far back does the rear one need to go? Quote Link to comment Share on other sites More sharing options...
Guest cletus Posted March 21, 2013 Share Posted March 21, 2013 front one=no more than 150 mm back from the front uj middle one= no more than 150 mm behind that cv in the middle of the shaft Quote Link to comment Share on other sites More sharing options...
Guest k-trips Posted March 21, 2013 Share Posted March 21, 2013 Roogeer that rubber ducky Quote Link to comment Share on other sites More sharing options...
Guest durty Posted March 22, 2013 Share Posted March 22, 2013 My car from factory has shitty park lights (little 5w things) keep failing wof on them not being bright enough. have run dedicated cables to them from battery and they dont go any brighter, cant get a bulb that fits in the holder that is any higher wattage. Is there anything in the rules stopping me from just hooking the headlights or foglights up to the park light switch instead and saying they are my parklights? Tried reading the VIRm but cant figure out where park lights are covered Quote Link to comment Share on other sites More sharing options...
Guest camo_78 Posted March 22, 2013 Share Posted March 22, 2013 I have a question regarding doors,namely the barn/ambo style doors on the back of my mk2 escort van.is cert required if I make them into a one piece door??will still use factory escort hinges on one side and factory escort latch moved to other side obviously.just checking because I don't want to do it AND then find out I need cert,lol Quote Link to comment Share on other sites More sharing options...
Guest cletus Posted March 22, 2013 Share Posted March 22, 2013 My car from factory has shitty park lights (little 5w things) keep failing wof on them not being bright enough. have run dedicated cables to them from battery and they dont go any brighter, cant get a bulb that fits in the holder that is any higher wattage. Is there anything in the rules stopping me from just hooking the headlights or foglights up to the park light switch instead and saying they are my parklights? Tried reading the VIRm but cant figure out where park lights are covered dunno. had a quick read and it doesnt look like there would be anything to stop you doing that. but you could guarantee you will have dramas telling your wof guy that and getting him to pass it heres the bit in the virm http://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/lighting/forward-facing-position-lamps Quote Link to comment Share on other sites More sharing options...
Guest cletus Posted March 22, 2013 Share Posted March 22, 2013 I have a question regarding doors,namely the barn/ambo style doors on the back of my mk2 escort van.is cert required if I make them into a one piece door??will still use factory escort hinges on one side and factory escort latch moved to other side obviously.just checking because I don't want to do it AND then find out I need cert,lol yes that would need cert. Quote Link to comment Share on other sites More sharing options...
Guest durty Posted March 22, 2013 Share Posted March 22, 2013 dunno. had a quick read and it doesnt look like there would be anything to stop you doing that. but you could guarantee you will have dramas telling your wof guy that and getting him to pass it heres the bit in the virm http://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/lighting/forward-facing-position-lamps Sweet. Will give it a try tomorrow and see how I go Quote Link to comment Share on other sites More sharing options...
Guest Dell'orto Posted March 22, 2013 Share Posted March 22, 2013 My car from factory has shitty park lights (little 5w things) keep failing wof on them not being bright enough. have run dedicated cables to them from battery and they dont go any brighter, cant get a bulb that fits in the holder that is any higher wattage. Are they a wedge type bulb or bayonet? If they're wedge, you could get an LED replacement which are about 50x brighter. Quote Link to comment Share on other sites More sharing options...
Guest durty Posted March 22, 2013 Share Posted March 22, 2013 Are they a wedge type bulb or bayonet? If they're wedge, you could get an LED replacement which are about 50x brighter. bayonet, are the size of dash bulbs, useless little things, for the last wof I got my bro who works at BNT to find me some phillips 15w halogen replacement things that were $19 each at staff price and used them to pass the warrent but they blew within a month so didnt want to do that again. Anyway went for wof with them hooked up to the headlights instead and failed on it but when I questioned the guy about it he had a look through the book and changed it to a pass Quote Link to comment Share on other sites More sharing options...
Guest Hachi-ichi Posted March 25, 2013 Share Posted March 25, 2013 Anyone care to help me out with Negative camber restrictions? What am I able to work with on top of Factory setting. Also what is the leniency on this subject. ( as in lets say im a wee bit out from the limit, visually not noticable ) Quote Link to comment Share on other sites More sharing options...
Guest cletus Posted March 25, 2013 Share Posted March 25, 2013 half a degree over the maximum manufacturers spec is the limit. only exceptions are vehicles under the authority card deal (competition vehicles) and vw beetles. Quote Link to comment Share on other sites More sharing options...
Guest e30-323ti Posted March 25, 2013 Share Posted March 25, 2013 ....and vw beetles. Is that in jest or serious? If so why? *curious* Quote Link to comment Share on other sites More sharing options...
Guest k-trips Posted March 25, 2013 Share Posted March 25, 2013 only exceptions are vehicles under the authority card deal (competition vehicles) and vw beetles. How do they determine the exceptions? Things like Heralds and anything with a de-dion tube rear end will vary more than half a degree when you put your portly mum-in-law in the back seat...edit - beaten Quote Link to comment Share on other sites More sharing options...
Guest datto_610 Posted March 26, 2013 Share Posted March 26, 2013 Same with Datsun IRS, Iv'e had to make my rear end camber and toe adjustable so just it's legal at the height I want it... Quote Link to comment Share on other sites More sharing options...
