Everything posted by Shandangles
shit i love this bro, perfect Z in my opinion.
Beans mk2 Cortina EFI & mk1 Cortina EFI Turbs
Shandangles replied to Gaz's topic in Project Discussion
this is unreal mate! amazing work!! -
every time i see pics of this im stunned. Its Perfect. SOOOOO MANY WANTS.
Lowering compression ratios on a 20v silvertop 7agTe
Shandangles replied to ae85 fiend's topic in Tech Talk
Just get Standard 4agze 8.9:1 pistons, cheap, readily avaliable and proven to over 500 whp in many, many cars -
use need-it, works a treat and is quick and easy.
cutting springs on your new daily as all other cars have pinkys seems slightly counter productive dont you think?? otherwise sweet, could film a porno in it with that interior lol
from memory 2" id piping is more than enough for 400hp, can t remember where i read it but is in the brain. not that it matters now with your 2.5" stuff
Brought some alloy front hubs from a company in Ireland called Group 4 fabrications http://www.grp4fabrications.com/ Paid for them on Monday and they were at my house Thursday morning, Epic Service in my book. The hubs are a direct replacement for the factory 86 ones but have an in built 10mm spacer & they look swish as shit Just need to replace the front castor arms as they are shit "hardrace" ones and bent, im thinking either Driftworks or T3 then the front suspension/steering should be all done. MAD!!!
fuck man, i just flicked through your thread and miss read & thought you flagged the RZ for a 20v because of the headers. THANK FUCK I WAS WRONG!!!!
and slip ons are a legal no-no also. and 16" momos, come on man...
all done, front is max low, rear can still drop about 30-50mm if i remove the height adjustment perch things. 14" settlies with flat tires prob dont help the levelness.
fitted stuff up, albiet the wrong way so the caliper is at the back not the front but its on and all fits and doesnt hit anything!!!! shit is close tho the grease nipple for the ball joint is like 5mm max from the rim with the 50mm RCAs 280mm disc in through a 15" sportmaxx / max suspension droop!!! sweetness discuss viewtopic.php?f=18&t=30651
well im back in the country and all my shit has arrived!!! about to go fit everything. The wilwoods and the MRP/Fortune auto have just been at the surfab fantasy factory getting the fronts welded up, had a wee steel plug made to go into the remains of the factory strut and the adjustable tube for a bit of added strength, was made by TRANSIT engineering on Francella st Linwood, Cheap as chips and took less than 24 hours, top service !!
you rule max,i want a ride/skid when i come back next month =)
yeah. have the car on axel stands and jack up the arm that the spring sits on till its captive, then jam the shock on to hold it there.
This. get it to hold the spring captive then 1-2 extra turns to hold it in there is how iv always done it.
boring picture-less update...... finally got myself back in the black so have started amassing stuff for the car have purchased 1 Bosch 044 fuel pump, 2x fuel pump brackets (1 for the 044, 1 for the 070) and some MRP/Fortune Auto coilovers, should be the goods, next will be the wilwood order =) edit, found a pic of said suspension, shit is flash
this will give you about 1/4 a turn each way http://www.ajps.com.au/parts/extra_lock_spacers.php
back in the day we got the K50 plate made into a 4 puk job by clutch systems with a standard 4age pressure plate and it was sweet as, never had any issues like that
ha fuck me someone is taking the piss with those electric water pumps. http://www.ebay.com.au/itm/DAVIES-CRAIG ... 085wt_1108 Its the better alloy pump and controller for mucho cheaper. have ceen them cheaper than this too
glow plugs would be my first bet, prob the cheapest and easiest fix too, possibly glow plug relay also. glow plugs will sting you like $25 ish from BNT or repco
Ling's Silver Grand Father ---- Plan B (NOT a SPAM THREAD)
Shandangles replied to LingLing's topic in Project Discussion
Learner Driver!!!???? all this effort to make it mint and you / your letting a learner drive it??? WAT! -
those wheels are so sweet for what they cost. my flatmate got a brand new set when they just came out for $500.
rear suspension , irs toyota ,BC coilovers . . .
Shandangles replied to ta63-1uzze's topic in Tech Talk
99.9999% of people with adjustables put them in set the height and thats it. thats how the majority of competition (drift) cars iv com across) are run, maybe the odd damper adjustment but iv never seen someone adjust preload "hardness" as you said it. and most of the stuff iv read lately basically says that all the cheapish coilovers (BC D2 Tein xyz cusco etc etc) the adjustment actually doesnt do sweet fuck all when put on a shock dyno.....
