Everything posted by governorsam
Golgwing any good?
Next one? Keen for a hoon with you weirdos.
- 9 replies
governorsam replied to Roman's topic in Tech Talk
Same with coil. Cool it down and see what happens -
Stationary radiator test is needed. do a skid cunt. send pics of result. lol
Superchargers run hot. Quick google of mustang owners said so. Its a heat/air pump. What happens when you squash air? it gets hot. just send it...
Its a rural speights pub. I like it.
still got a zx81 somewhere in the shed. and an amiga500 still in the box.
cut it to length and measure it. thats the belt number/length you need. saw it on skid factory somewhere. -
https://www.trademe.co.nz/motors/car-parts-accessories/austin-rover/listing-2320939739.htm?rsqid=0b8f1cb23dca4217856b7cfd30359464-001
What’s wrong with points? A new set and condenser work fine. Cheap, easy, no hassles.
Make shure you are getting fuel to the carby. Spent an hour trying to sort a problem when I did an engine swap when I was a lad. Had run out of fuel in the tank... keep it simple, look for basic things. What has changed since It last ran.
perfect for the mongol rally. https://pedrov.es/
Green stuff is factory to keep the coil windings apart. Use a test light to check for power, meters can give false readings on stuff like this. Looks like there is a circuit breaker in there? The 2 terminals on their own. The resistor circuits are usually the 4 pin plug. 1 in 3 out.
Hacksaw blade with the sides ground down was what I have been told works. Get in there and scrape it out. Then flatten with a bit of hard wood and hammer/ press. No heat. Any hammer marks will result in a fail at inspection time. Used to work at a truck place, this is what I was recommended by cof inspectors .
nope, sold the mk2 cortina.. might be selling this now though, time to slim the fleet down a bit.
