Everything posted by governorsam
Stationary radiator test is needed. do a skid cunt. send pics of result. lol
Superchargers run hot. Quick google of mustang owners said so. Its a heat/air pump. What happens when you squash air? it gets hot. just send it...
Its a rural speights pub. I like it.
still got a zx81 somewhere in the shed. and an amiga500 still in the box.
governorsam replied to Roman's topic in Tech Talk
cut it to length and measure it. thats the belt number/length you need. saw it on skid factory somewhere. -
https://www.trademe.co.nz/motors/car-parts-accessories/austin-rover/listing-2320939739.htm?rsqid=0b8f1cb23dca4217856b7cfd30359464-001
What’s wrong with points? A new set and condenser work fine. Cheap, easy, no hassles.
Make shure you are getting fuel to the carby. Spent an hour trying to sort a problem when I did an engine swap when I was a lad. Had run out of fuel in the tank... keep it simple, look for basic things. What has changed since It last ran.
perfect for the mongol rally. https://pedrov.es/
Green stuff is factory to keep the coil windings apart. Use a test light to check for power, meters can give false readings on stuff like this. Looks like there is a circuit breaker in there? The 2 terminals on their own. The resistor circuits are usually the 4 pin plug. 1 in 3 out.
Hacksaw blade with the sides ground down was what I have been told works. Get in there and scrape it out. Then flatten with a bit of hard wood and hammer/ press. No heat. Any hammer marks will result in a fail at inspection time. Used to work at a truck place, this is what I was recommended by cof inspectors .
nope, sold the mk2 cortina.. might be selling this now though, time to slim the fleet down a bit.
governorsams 1971 1600 gt capri
governorsam replied to governorsam's topic in Projects and Build Ups
- 20 replies
- 17
Try this https://docs.google.com/file/d/0B8kpZr-ZNJEYWnZYeDQ0VF9vZFU/ haynes manual for Kent engines
failed on exhaust leak, upper trunion bush, and a big hole in the back guard. (rust) am welding up the back, in between rain showers. have done all the rest, hope to be at hanmer later today...
Booked in for wof tomorrow.
