fulloc
Everything posted by fulloc
  1. or cam/ crank oil seal
  2. If the bilstiens have floating type alloy spring seats you could always get circlip groves cut lower in the shock body and just have it slammed with the factory springs? progressive spings are a good idea as they will be soft unless fully laden. i believe a lot of euros have very long springs with thick wire diameter but tons of coils. more coils is softer but thicker wire is firmer. autolign can help the boys in the workshop know their shit i worked there about a year ago.
  3. 5/16 aka 8mm is the norm i believe
  4. ive had good dealings with chamberlains and they know their stuff +nz made is alway a winner
  5. Autolign dont modify springs
  6. Those are just standard man. you can get Xenon gas ones from hella which are a bit better or the Narva Plus 50 range is pretty good. You can also get HID kits to wire into an H4 setup. pretty easy and real cheap. just not vtnz legal.
  7. fronts will slam it. rears are no good
  8. Its all good mate, good on you for having the cash and motivation at your age. I like it. the JZ is a massive win, your tinfoil intake makes me smile
  9. Would need to be a complete one off due to steering box wouldnt it? good luck
  10. BTW Nutech is a bitch to work with, more of a hole filler than a shaper
  11. Do front radius rod too and control arm. Also make sure steering is tight including rack mount bushes or idler/ tie rods etc.
  12. fulloc
    fecking brakes
    Need to bench bleed the master maybe?
  13. Word. Cost me over $500 to freshen my smallport at cost price.
  14. Yea discounts on. PM me for whatever
  15. il look them up tomorrow and see if i can help
  16. i commuted from the shore for years its not that bad.
  17. mate has a complete block if you want. cheap
  18. Position coming up at my work in penrose. Basic parts supply to workshops/retail. Aftermarket parts. If youre an experienced parts guy or mechanically knowledgable and dont drive a cefiro on chromes then get in touch and ill try tee you up. Dylan
  19. -10 at idle i think? mine is and that seems to be what most toyotas ive come across run. different setting for limp mode though
  20. It doesnt look that bad id try head gasket only and see. What do the bores look like? Could pressure test the head and go from there?
