Everything posted by xsspeed
If it planes ok then that's good, permatrim really just helps them get out of the hole, they are just a foil afterall
on ya, good to be out there doin it did the motor get you two up on the plane at all or just good to chug along?
Interested in hearing prices from autolign for bilsteins. Still havent scratched the surface on coilovers for fairlady
Yep confirmed to be as good as fwd bluetop
fuck me what a bigport barry, this thread is bad for my health
so likely a ae92 bigport/2nd gen AE82 fxgt at least didnt have those mounts, was single piece rad hose around cambelt side of block. Can't speak for AW11 though
https://www.toymods.org.au/forums/threads/28455-I-D-this-4AGE/page4 is this what you've got? edit: yup
I have no e80s to look at anymore for reference lol. You'd have thought I'd remember. Drivers side mount on ae82 is definitely different to e90, possibly was off the block (rings a bell) I'll look at some old pics
I thought all bluetops were equal and the revision came with the 2nd gen bigport that was in early ae92s This had the bigger crank, could it be that @kytelers head was actually a 2nd gen? Would more likely explain the intake difference to me In4bluetopnangs
@kyteler endorses gold mesh
Went alright torrie? I didnt even know they had DA polishers at all
its got some accident damage that needs to go in for repair but was going to get them to quote for full paint. plan is to tidy it up once then run it into the ground (again)
want to paint a BA falcon wagon?
increasing the velocity of rotation as it tries to conserve momentum?
hah was trying to work out what that was
is this a project thread or a discussion/i love the spare forlornly falling out after the roll
/first boat nats was about 10 years ago...there were 2 boats
Seeing you're unemployed again pete I think it's time to get this going
Thirsty thursday at Barts, this thursday 1-10-2020
xsspeed replied to RUNAMUCK's topic in South Island Region
Better check it has oil then puhuhu /blue smoke -
highlight of day seeing startup vid on the gram, well done ol chap
Poorly explained sorry, I mean in the areas not covered by roof, does it fall away from the carport or direct water in? Overland flow It will drain yeah, but not as good as normal lawn right, so you could get standing water if it's a spot that will collect water. From memory your site is pretty flat and falls down to the footpath so you might be sweet
So use the right materials and prove its within a safe tolerance (x%?) Of original state as demonstrated by a physical test (what test?)
