Everything posted by tortron
Repainting Underside floor and chassis of mitsi Ute. Thinking of brushing a few kgs of zinc (CRC zinc it) on. Or should I just durepox it?
Probs ok with no boost
https://www.classictransmissionsolutions.com/700r4-speedo-electric-to-mechanical-conversion-kit-convert-speedometer/ doesnt help the ppm to ecu problem, but theres other was you could do that, like this https://shop.classicinstruments.com/sn78sm tail housings with both mechanical and electronic speed sensors are available but at about $600 less mucking around to get the dakota unit
Sounds like something a bicycle builder may have
Thought about a UE boom sorta thing velcroed to the parcel tray? then you can also take it with you picnicking
Door fits Opens without hitting anything Closes without hitting anything Is parallel with B pillar Is parallel with sill opening Sits flush everywhere All it took was totally reshaping the guard. Some spots were way out. The rear mounts had been welded on crooked. Added about 5mm in some places and skimmed a mm off in others Need to add a little at the A pillar, and probably add a little to the A pillar bottom edge itself. That lower bend/angle was different on the B pillar,door,and guard. At least it closes now FFS
- 138 replies
- 15
Rusti'z 1920-26 Ford T bucket (of rust) Discussion
tortron replied to Ghostchips's topic in Project Discussion
It's woffed and regod, beats most cars on here -
Thats a cool shot on the beach there Rusti. pretty amazed that you would put the wrong hood on your 2022 dodgy wofed electric car tho WHO WOULD DRIVE THAT -
Yes. Still considered a flatdeck if it's a beaver tail too
Yes within the last year they either changed it or started cracking down on it as all the trucks at work had them installed within a week
Literally never seen anyone use park lights as park lights tho
NZ road code A motor vehicle must not be parked on the road during the hours of darkness unless it is clearly visible to other road users. This means it should be lit by street lights, or you should turn on the tail lights and the side light nearest the centre of the road on the front of the vehicle. A light, flat-decked vehicle that is parked on the street at night must display a rear red light that: is on the side of the vehicle closest to the centre of the road is visible at a distance of 100 metres.
- 502 replies
Key to success
tortron replied to h4nd's topic in Other Projects
Had some pipe left over (it's also splashed in pigs blood from homekill, so it's a pleasure to weld yum yum) A decent little length, looked about BBQ height, so I scrounged up all the rusty scraps that were too good to throw out, and made this rocket stove. Should have cleaned it up better and not welded outside in the wind. But a tidy up and some Potbelly paint should tart it up. Once I've cranked some temperature in it to burn off the galv as I don't want zinc in my food. lower bit is solely for air intake. Might fandangle something up to control it for simmering. Although fuel is probably the best way to control temp.- 1293 replies
- 15
Occasionally see used malpassi siding rate pressure regulators for carbs come up on TradeMe for not much. They are about 200ish to buy new. Maybe cheaper on ebay
- 1293 replies
At least it was easy to push?
Here's a guy who DIY'd his DR with a microsquirt https://thumpertalk.com/forums/topic/385464-winter-project/#comments
I looked into that for GN. There's some not so cheap small engine kits online. https://www.ebay.com/itm/FAI-motorcycle-scooter-buggy-moped-UAV-EFI-engine-Electronic-Fuel-Injection-kit/273178456487?epid=15030398723&hash=item3f9ab471a7:g:hkIAAOSwqHBa4KTu Or get a wrecked f.i. scooter and go from there
tortron replied to yoeddynz's topic in Project Discussion
This guy does control boards for getting rid of the canbus gubbins from leafs https://pandspowerelectronics.ecwid.com/
