tortron
Everything posted by tortron
  1. tortron
    PAINT THREAD
    The round ones? I have a shit ton of these organic filters Can send you a bag full along with a pile of prefilters
  2. The cores I have enquired about have started at double that and gone up
  3. Oh that's it, looks like fuel filler and small gauge below it on this
  4. On the tank? You get used to it after a day
  5. Stitch up, fill with expanding foam. I saw it in an ,surprisingly not Pakistan, American shit old tractor not worth tyres video
  6. Some modern window winders could be found in either a y10 or y11 nissan advan. The povo spec ones had them. Possibly same spline being a Datsun wagon but 25 years in the future
  7. Try some wheel bearing grease smeared on the outside of thr throttle shaft to help keep the air out when tuning Also keep.all your worn out carbs in a nail box for me thx
  8. Got given one of these smootharc 185 arc tig Possible intermittently not welding, but I haven't looked at it yet. Is anyone using one?
  9. I once tinned a slightly worn SU throttle shaft with solder and lapped it into.the housing with jewlers rouge. Good for when they are just starting to get too much slop.
  10. tortron
    PAINT THREAD
    I used John Deere satin black in my morrie, like 15 years ago. It's still on, still satin, still black. I haven't noticed any particularly gloss parts, but I probably only wash the dust off once a year
  11. 0000 steelwool and petrol/kerosene for chrome rims and motorcycles forks. 2 part epoxy for the pits
  12. Imagine the fireworks display after an all lithium electric derby Probably only 5-10 years left of them I guess
  13. https://www.nzta.govt.nz/vehicles/vehicle-types/motorcycles-and-mopeds/information-for-moped-riders/#equipment
  14. But what about non wof moopeds Headlights on if built after 1980. Use hands if no indicators or brake lights
  15. Did some more Useful for dialing in the scanner, screen, and printer colur correction. Directly scanned and printed was coming out way too dark for whatever reason (maybe the 1998 scanner)
  16. Made a brass dome out of an old solex carb float And fitted with a file tapered pin made from a microdrill shank. Nice tight fit. Clock has been ticking away happily the last few days, with no hands, so will see how it goes now. If the hands don't interfere with each other all good, otherwise might need to space the minute hand up with a tiny shim. Then il go about getting it in time, probably paint that brass bit black to match the hands. And that's it, lovely old 8 day kitchen clock back in service, fixed with junk laying around my shed as is my usual turd polishing way
  17. Made a new one From what I can see online, the minute hand is held on by a threaded cap. Mine has a square shaft with no threads, but does have a hole drilled through it (which probably hints as to what year it was made) This is, or was common on clocks, there will be a cupped washer which will press down over the hand, then with some tension on it you poke a rod through the hole and it all holds together
