Everything posted by ESKIN8R
The viscous fans are screwed onto the water pump, the bolts you removed dont need to be. At the back of the fan you should see a big nut? Hold onto that then stop the waterpump pulley from turning and then unwind the whole viscous assy. Should be Left hand thread I think, unwinds the same direction it spins.
Hi, Sounds to me not to be your engine at all, If you had a big end knock it would be there all the time. You'd hear it badly if you had it and reved the engine it would have a clattering noise, could be something like a driveshaft universal worn casuing the noise? Or other suspension related noise.
Where are you located? You should throw up some pics of your car in the Projects section
Hi, welcome to the site, follow this link for some advice viewtopic.php?f=48&t=6363
Whangarei meet: Sunday 30th October 2pm nandos
ESKIN8R replied to bigfoot's topic in Upper North Island Region
Can't make it on that day, bummer -
I don't reckon the vans fetch less, the good examples are worth good money, its just that most are rust/bog buckets. Most sedans seem to lead a easier life and can be worth more due to condition? And yeah Id like to get the front down a bit more
Motors all good to go, have pretty much everything to do it, just gathering a few more funds to paint engine bay and do a few other bits and pieces then its go time! That Weber turned out to be not suitable, was a DGEV ( electric choke ) converted to manual and was too bulky out the side ( Would hit my rocker cover ), have a new one now that will work perfectly
Lol I also owned a van KD8753 even closer relative, this one was bitten by the rust bug in a big way though...
Heres my induction setup, wanted to keep it driveable with the 32/36. Its a Brand new DGV 32/36 manual choke to keep it simple.
Fully rebuilt, balanced, fitted the stronger '205' rods ( that block doesnt have those normally ), ARP rod bolts, new pistons, lightened flywheel, group1 valves in head, Head ported and filled by Nismo.Capri ( cheers man ), FR30 Kent cam kit, and more
Yes its everyones favorite engine...Looks prettier than most tho viewtopic.php?f=18&t=24786
Ghia's are sweet, wouldnt mind one myself, but 3 escorts is too many lol.
Sell you one for $100 if you want it... was sold as being new to a guy I got a bunch of parts off from a auto electrician, but looking at it appears to be recoed rather than totally new
I also have a recoed inertia and pre engaged starter I would sell if you want
Did you swap the ring gear to match? Each starter has a different type...
This almost always never works out, but Id be keen if it does... -
Thicker strut tubes so basically stronger, unless rallying shouldnt need to change from standard
Get in touch with hrdengines on trademe, they may be able to help with your two door bits.
many OS members in whangarei/ far north area?
ESKIN8R replied to rb drifter's topic in Upper North Island Region
Ahh its so nice to see my sport In your Sig bigfoot haha. Im in Whangarei too, Mk2 Esky Van and a Mk2 Sport ^^ Red one there -
PM Mackaz he might be able to help, cant say I know much bout toyotas 's
Fuel supply issue perhaps
See that driving around all the time
What sort of car?
