Everything posted by Nominal
Prob too busy for me, catching a ferry early Friday. -
More likely BSP than NPT I would think. I've got a temporary brass manual tap on my Minor at present but one day I'll put this one in (came with a NOS ADO16 heater kit I got years back)
- 70 replies
- 27
Nominal replied to tomble's topic in Project Discussion
Yeah, but then it wouldn't be as Mitsi built it! -
Nominal replied to Truenotch's topic in Project Discussion
Crikey, who loans out race cars? -
I had to buy 250ml of durepox hardener recently as the previous lot had gone off. It was $27 just for that.
I buy Durepox as a 2-part from Resene Automotive (RALI) in Naenae. Have sprayed it, but mostly mix and brush for small areas as Spenno says.
Did I see you fixing a broken down Falcon(?) or something?
Mostly you need it to enter the official cruises to get into the special parking at the end of the runs - Waihi, Whitianga, Onemana, Whangamata For the Onemana one, you need to second sticker they put on when you line up at the start so people can't join 1/2 way through. There is also a special entrants-only draw for $10k on the Sunday.
Promises promises
Have had no problems using the properly marked cu/ni tube from a brake shop.
Nominal replied to johnnyfive's topic in Upper North Island Region
Is the prize a GN250? -
K-Trips 1982 Holden Commodore VH Discussion
Nominal replied to KKtrips's topic in Project Discussion
Looking good there KK It's amazing what they can do with bog these days. J/K, looks sweet. -
Looking forward to seeing the dicks brakes:)
- 138 replies
K.E.E.N. -
Yeah, I'll just clamp a bit of hose on the cooler ports Need to block the speedo drive hole (as I found out last night while lifting it)
Thanks Rogee, name is the key, Do you reckon they would work when the engine is going and tranny is in Park?
C4 BNT didn't have Type-F fluid either. Disappoint I wanted to fire up my 'running' flathead to show off to the Morrie Club this weekend, but don't need trans fluid all over.
