Everything posted by Nominal
Nominal replied to h4nd's topic in Other Projects
Took it up to PNorth to get hot dipped as I don't want it to rust. Then painted with Galv One primer and black lumbersider on top. Pretty happy with the outcome, should have got on with it sooner- 1289 replies
- 29
This year I got sick of the space it was taking up so decided on a sun shape to fill the sides, made the flames using the little forge and anvil and bent the rings rather dangerously on the old lathe and welded them in.- 1289 replies
- 20
Must be getting close to 20 years since I started this garden archway. I bent the hoops to an elliptic profile (which looks better than 1/2 round) in the early/mid 2000's then it sat around getting in the way like this until the first 2020 lockdown when I finished the lattice on the top -
Charge them T&M for returning it?
How come the XJ8 is a cheaper purchase? Also, Land Rover is high performance? That exclusion is wide open to interpretation.
Factory wouldn't use shit clips.
K-Trips 1982 Holden Commodore VH Discussion
Nominal replied to KKtrips's topic in Project Discussion
That's a good looking 308 you've built! -
Tig welder question This is my machine, will it work with the type of torch that connects separately for the power (in the - terminal) and gas (where the tig torch connects now)? I kinda assume so because you can buy adaptors that do the opposite?
I've made a couple, just be sure it won' fall to pieces. No special inspection unless its a proper heavy vehicle.
Urban Dictionary: FWG
Usually the mechanical mechanism moves a different part, not the hydraulic piston?
Nominal replied to tomble's topic in Project Discussion
Nice work on increasing the collection size, always hand to have a parts car or two or three -
Duke Blackwood has crabs. 1968 Morris Austin 1100
Nominal replied to The Dude's topic in Project Discussion
That doesn't seem right, winding the T-piece down should push the shraeder valve down to let the fluid in/out of the system. If winding it out doesn't seal let the valve seal then something is out of whack. Can you dismantle the valve? -
I think we need a 350ZX there for test drives / clutch drops -
I'll be there! -
Electrical wholesalers usually stock them I think?
Is it done yet?
For a 1977, rear seatbelts are not required as per this table Seatbelts and seatbelt anchorages - NZTA Vehicle Portal Rear brakes don't much of the work so probably not worth upgrading. Doing that would push you into needing lvvta certification, and I think you are going for stock-ish for the rest of the build.
Split pin in bellhousing is just a jiggle pin to keep the hole clear for oil leaking out.- 24 replies
