Truenotch
Administrators
  1. The answer is simple: Fit roll cage, get MSNZ Authority card, fit race harnesses and add as much camber as you need .
  2. Welcome back! You can upload your photos straight to the forum now. See the little “click to choose files” button at the bottom of the text box. Cool cars btw, the E36 will be quick!
  3. That's sweet! I was pretty confused when I offered the 100 motor up to my frame... The mounts are about 10mm wider than the FS1, so not easily fitted without taking some meat off the motor or frame mounts.... Not worth it yet...
  4. Did the YB100 motor bolt straight up to your bike? I’ve bought one but the mounts are wider than the little 50. Already ditched the battery and added a Trail tech .
  5. I’ve been ignoring this thing for a while, but am sick of it being in pieces in the shed. I needed to replace the piston after East Cape and decided to give it a quick hone beforehand.... but after a series of screwups that I’d rather not discuss, the lower skirt of the cylinder is now broken beyond repair. Note: cast doesn’t bend. After all that I decided that I wasn’t happy with the Chappy style cylinder anyway. The transfer ducts were too much bigger than the standard FS1 ducts which would have caused some strange flow. It used to rev better with the original cylinder anyway, so I’ve decided to go back to an FS1 style cylinder. The biggest available at the mo is 43mm/60cc, so that’s what I’ve ordered: But I didn’t want to throw all my good parts away, so decided to make the Polini carb fit up to the standard manifold. The standard carb fits a 20mm sleeve and the Polini hole is 24mm. Enter @Geophy who spun this up for me: Threw a couple of slices in one end so I could clamp over it. The clamp is chopped off an old carb. It works a treat! Carb goes here: It pokes out the side, but that’s life when you put a big carb on an FS1! I’ll have an air filter just above my brake pedal but i think there will be enough clearance. ... I might make some sort of cover to tidy it up later, but for now, it works. All this means I’ve got empty space above the engine again. I’m thinking if re-fitting the OG filter housing and using it to hold a tool kit and spare spark plugs. Now to wait for overnight parts from the UK!
  6. Updated. Here's the facebook event link: https://www.facebook.com/events/603593986795469/ Burgerfuel are having a launch party for their new Smack and Cheese burger. There will be a DJ, prizes and giveaways on the night. No cruise, just meet at BF Rototuna at 7pm on Thursday May 23rd.
  7. Anyone keen for a meet this month? There's a new burger being launched and Burgerfuel Rototuna are going to host a bit of a party. @Archetype @64valiant @Geophy @Beaver @mark105 @Zeubin @Yowzer @SHGWAG etc.
  8. Wow! It looks completely different to last night. Good work. So much extra storage space .
  9. Yep, the bolt shop are terrible.
  10. If there's interest, they'll be back.
  11. The meets are on hold at the moment. So of course no one will turn up...
  12. Yeah, that live axle life is tricky! I've been trying to come up with a nice solution for a while. I'm always worried that the air will catch the top of the diffuser panel and cause more harm than it's worth. Stiffer springs makes sense too. The more aero grip you generate, the less spring compliance you need (in theory). What rates are you running at the moment?
  13. Do you have adjustable brake bias? If so, you might be able to dial out some of the unsettled braking in the rear. Pretty curious to see the effect of the diffuser though! Keep the updates coming.
  14. I'm impressed that you've dropped a second off your lap time from the front splitter and ducting mods! I wouldn't have thought it would be worth the effort at 12kg... Nice work on all of your developments by the way. You're doing everything I've been thinking about for the last couple of years . Are you going to add side plates to the rear diffuser?
  15. I reckon white /white or white engine bay with gunmetal steel tube.
  16. @Testament runs R888's on his Fiat 124 and has done quite a few Ks on them. They'll blow away any road tyre in performance and will be fine for a weekend car. They can be a bit noisey, but otherwise are great.
  17. IMO it will be a good idea to have a decent amount of droop in the FD. I did a shitload of R&D for my MX5 suspension mods last year and found that droop travel and good urethane bump stops are both key to good suspension for the road and track. MX5's are pretty limited in compression when slammed and I assume FD's are similar. Adding good bump stops and utilising droop travel are two tricks to maximise road holding ability. Your keeper springs will need be a bit open at full droop - just enough to allow for that extra 15mm of travel. You can buy keepers from 25mm up to 70+mm in length. I would recommend something like this: https://www.trademe.co.nz/motors/car-parts-accessories/performance/suspension-braces/listing-2000560762.htm?rsqid=f6b126ce4b604edab9abc14c8ddcb068 40mm uncompressed length, 15mm compressed length, 3mm retainers. This would give you loads of room for adjustment and more than enough extra travel. You'll need to drop your spring perches by an extra 18mm from where they are now to account for the compressed spring and retainer, so they'll work well as long as you have that adjustment available.
  18. Good stuff. You can get keepers in a few different lengths. Get some that give you as much travel as you need with a little left over (so the keepers are always slightly compressed). This will give you more flexibility for ride height changes in the future and also means you can adjust your ride height from the spring perch, instead of the lower body.
  19. @Toddy415 - here's a simple guide from MCA suspension on how to gain droop travel with coilovers like yours: https://mcasuspension.com/technical-section/Ride-Height-Adjustment MCA don't talk about keeper springs because they don't run them in their race cars. Your springs will need to be captive for a cert, so you'll need to add a keeper spring with enough travel to allow for the extra droop (which also means dropping the spring perch a little further to account for the compressed length of the keeper).
  20. This is only partially correct. The only reason to adjust the body instead of the perch is to keep the spring captive when making adjustments. It’s worth noting that doing this could also limit your bump (upwards) travel by causing the tyre to hit the wheel arch under full load (depending on total shock length etc). Adding shock length as required, lowering your spring perch and installing keeper springs should allow for lots of droop travel while still retaining enough bump travel. Droop travel is more important than compression travel in some situations like big bumps and drop offs.
  21. Do you have a pic of the shocks? You should be able to adjust the body length and the spring perch if they’re the style I’m picturing.
  22. What's the car and are they body adjustable? The correct way to get more droop is to add keeper/helper springs to your setup. It's easy to do, and if your coilovers are body adjustable there should be plenty of adjustment (body adjustment changes the total length of the shock). Here's the process I would follow: Remove springs and run suspension through its whole sweep with the wheel and tyre on. Take note of how much clearance you have at full compression (if any). You should aim to have the tyre as close to the wheel arch as possible at full compression for optimal handling. Make sure there's enough clearance for the bump stop to compress a little for big bumps (10mm minimum gap between tyre and inner guard). Use the shock body adjustment to set this height. Jack the car up and see how far it droops. Measure the distance between the centre of the hub and the wheel arch at both ends of the sweep to give yourself an idea of total available droop travel. Install your main spring (no keeper) and drop the car on the ground. Set your desired ride height for cert using the spring perches. The spring will probably be un-captive after this. Once ride height is set, jack up the car again and see how far the spring is from being captive. This will give you an idea of how long your keepers need to be. Install your keepers with spring locaters between the keeper and main spring You will need to drop the spring perch to account for the compressed length of the keeper plus the thickness of the locater to get the same ride height ??? Profit If you don't have enough perch adjustment, you might need a shorter main spring. Hope that helps.
  23. I think it’s going to be put on hold for a few months.
  24. Truenotch
    Diffs
    Ahh, diff stuff. Here's one of my original 24mm axles I broke in the racecar... It made a mess. The original axles were mild steel and had been known to break for the car's entire life (it's got a custom floating axle rear end). So I got Howat Engineering to make up a couple of moly axles. These were the same size as the originals. The ends were hardened in an unknown way, but you can see the difference in colour on the splines: Business end: Big end: Funnily enough, I also ended up breaking one of these... It had created small fractures where the splines mesh into the side gears and broke into a psychedelic star shape which is quite interesting to look at. I think all my broken axle ends are still on a shelf in Dad's garage in Palmy. My next step was to get the side gears in the diff taken out the 28mm (same size/spline as an F series Toyota) and then got them electro hardened in Auckland. The current 28mm axles are the same style/manufacturer as the ones pictured above. They've lasted well so far and have taken the abuse, but I'm sure the splines are starting to stretch and wear slightly from my heavy clutch and aggressive left foot (although it doesn't matter at the mo as the car is sitting in the garage... in pieces.) @johnny.race - do you have the ability to make whole axles from scratch like the ones above? Because I might need your services one day.
