Everything posted by sentra
I made a video of it
Can anyone explain a mystery why on a big old diesel motor if I pull the dipstick out after running it’s dry, but If immediately dip it again it’s full - like magic its like there’s something hydrophobic (oilphobic???) on the stick after running same deal if I shut it down and leave it until the next day, first check it’s dry, second and any subsequent checks it’s full
does anyone know why small vertical shaft engines make so much less power than horizontal engines he same cc do they grind the cams for lawnmower rpms?
please fill it full of french electrical problems joe
Eastcapescapade #6 2022 November 11th, 12th, 13th
sentra replied to johnnyfive's topic in Upper North Island Region
is that a snorkle under your seatpocket tori -
if not john brooks then optibelt carry them in nz also
ive been proactive and prepped too far in advance and now there is enough time to break both bikes. -
cheeers did you take that pic special?
what is the best tool for crimping those narva insulated terminals? i think ive seen a hexagon one that crimps on all sides like a hose crimping machine?
with state of the art electric valves, compression, manifolds etc - how far can the island be moved? the tides coming in.
but i want you to do it
A 2T will do 15k+rpm, why haven’t we seen gearboxless cars that do huge rpm’s and slide the efficiency band around with modern variable everything technology? Is it a big-cam conspiracy?
can you guys hassle me to organise a chain & sprocket for ct and also a piston for sue -
You riding from Auckland? -
woke up in a panic this morning from a dream I was in j5’s paddock at the start of this trying to fit the engine in while everyone roared off tonight job is to fit the engine then -
bloody hell fletch your going to lose your licence/crash into the paetiki bakery like @Testament
has anyone used a china 4x4 winch? i want one for my boat trailer, it will live outside with a tarp over it, curious if they actually produce the line-pull that they state trying to get a runva one but they are pretty hard to deal with.
was this in clarks beach last weekend? cool/unusual sight and drove past very slowly on the open road.
shit i was confused here - (this is dave) @Lt Danand @Lt. Dan theres two of you!! what are the chances one of them fixes the ambulances, and the other is doing his best to end up in one. did they have to back that truck all the way out?
MOLESWORTH MOPED MELEE, 4th, 5th, 6th March 2022
sentra replied to RUNAMUCK's topic in South Island Region
bort you need to make molesworth happen theres no ifs or butts -
oh cullen youve done it again
https://www.jaycar.co.nz/assorted-solder-splice-heatshrink-pack-42-pieces/p/WH5668?pos=19&queryId=e4b346968a1f3b9b158e89ea006bef48&sort=relevance just use these for everything ive started trimming the crimpy end off ring terminals and joining them to wires using them aswell instead of crimping them, so conveinenrt
those pure nickle rods on an stick welder are amazing and make a first timer look like a pro. you would probably weld everything with them if they weren't so expensive.
