Everything posted by Jusepy82
Heres the 250 with the donk out and spare motor awaiting attention. The kick start one way bearing is toast in the motor that was fitted and also has a bad oil leak. I picked up a whole lot of parts and another engine for a 100 bones , pretty stoked until I found the sump bung was welded on the motor I brought Oh well see what happens....
Here is the 250 when I first got her , I have since rebuilt the carb , unseized wheel bearings, repaired the wiring/wired in correct wires for the cdi , had the engine running and removed the engine from the frame
I have a new seat cover for the 200 but have not found any suitable foam and materials to refurbish it myself yet.. any suggestions would be mint thanks
Hey guys and girls. I have two honda ATC's, ones a 84 200es which is up and running. The other is a 85 250es which I have had to do minor repairs and also repair the frame down by the foot pegs as it is completely rotton I fell in love with the trikes and have become slightly addicted to them. Here is a pic of the 84 200es I want to get the 250 up and running then I can pull the 200 to bits and clean it up .
DABUZZ'Z 1971 MAZDA CAPELLA RE + New 74 RX4
Jusepy82 replied to dabuzz's topic in Project Discussion
Well thanks for the build thread. Gave me inspiration and hope for my build. -
Had a little play with my welder today. Complete fail , feel like I'm back at square one but as the old saying goes " if you dont use it , you loose it" Time to put in the effort and learn.
Looks awsome man !
Well done man !!
K-Trips 1982 Holden Commodore VH Discussion
Jusepy82 replied to KKtrips's topic in Project Discussion
I like this -
Have any of you guys done the cube challenge? Mig/tig/stick weld up a bunch of pannels to make a cube. Was thinking of doing it to get too where I need to be to do more repairs on my escort. It gets pretty boring laying weld after weld on a flat piece of steel. Any other ideas to make welding practice not so tedious and boring ?
Hey man , Hows the escort gooing ?
You SIR are a gentleman and a scholar !!! The parts will be greatly appreciated ! Im not looking forward to taking my swingarm off as it pretty rusty where the through mounting bolt goes in. Ill pm you
Where abouts are you @johnnyfive ? How much are you after for the frame And the brake setup? That box section around the foot pegs is where mine has rusted out . Also check your swing arms underneath that towing hitch as mine has rusted through behind it.
@johnnyfiveyou dont happen to have rear brake assembly spare too lol. Noticed tonight mine have seem to be missing. Yer everything:(
Man , that looks like soo much , Love hearing the starlet rev out and watching you busy as behind the wheel ! Keep up the good work.
Hey man , nice escort ! There is a guy on youtube that has done the front wing/guard repair and has done it stage by stage so you can see how it is done. Check it out , makes it look pretty simple using cardboard cutouts as templates. I started doing my guard following his directions and so far so good.
This thread is giving me ideas for my nifty 50 !
Tonight I had a look into the carb over fueling as I had to drill out the slow jet as it was blocked solid. I ended up drilling it out but I think its fucked now as its pouring fuel out the back of the carb. So I disassembled the card , ready for when I buy a carb kit for her. I thought I'd look into the wheel bearing play on the left hand rear wheel. Took the castle nut off, which was loose, had a quick look at the splines of the hub. They looked ok, so I tried to crank up the castle nut to no avail. The split pin wouldnt fit through the hole as it's not wound on enough. I removed the hub again and had a look at the wheel bearings and it seemed they wernt pressed into the axle tube enough. So I punched out the bearings and cleaned it all up , what a mess ! Anyways reassembly another night as I'm dangerously close to too many beersies for this kind of mechanical work. Cheers
Thanks man , What sort of condition is it in ?
Also if anyone has a 250es frame for sale let me know , thanks. Comments/opinions/advice welcome.
Hello friends , so I decided to get my 84 honda atc 200 a big sister , although she is a bit sick at the moment. I brought the 200 and got it going well but decided I needed another trike in my life. Sooo I brought the 250es from a guy up by Horopito car museum. Got it for a steal but boy it's a big job. frame rusted by foot pegs, motor not running , massive oil leak from left hand side cover . I have fixed the side cover gasket and also had the motor running now. I put the 250 up on stands tonight so I could make this build thread. So far I've brought a second hand CDI for it , brought another rear rack and fixed the wiring and repaired the wiring behind the kill switch. The previous owner couldn't get it running. I plan to get it purring , then strip it and repair the frame. cheers. Sorry bout the novel. top bike is the 200es that hoons.
Hey man. I just happened to buy a 250es aswell. You dont happen to have a cdi for one or know what cdi's will replace the OE one.
@MightyMoose one like yours brother !
