ajg193
Everything posted by ajg193
  1. Even swapping cylinder head type on the same block will require cert AFAIK?
  2. The car survived a trip over the port hills last night with no issues at all. I'm starting to like it. Today I spent time working on the drivers side front guard and straightening the front bumper. The guard is coming along nicely but I ran out of wax and grease remover so I'll have to leave it until tomorrow before I do any more work.
  3. Pictureless update this time. So after the previous work I encountered some more problems engine-wise. The rumble ended up being the water pump letting go. So I replaced that with a new unit. When I replaced the water pump I discovered one of the pipes on the thermostat block was corroded past the point of being usable so I had to replace the thermostat block. I also replaced the thermostat and alternator belt. I replaced the ignition leads and distributor cap after getting a shock. I transplanted the vacuum advance unit off my old points distributor from the Sprint onto the 3K as the vacuum advance wasn't working. The choke now works properly. I made it half way down my road when the car just stopped. One of the LV wires on the ignition coil had fallen off, so I put it back on and screwed the nut on tight. The carburetor is still running the original 2K jets so it would be nice to track down a set of 3K jets as the car runs a little too lean when starting up from cold - needs more than two pumps of the accelerator before turning the key. I replaced the seal between the oil filter mount and engine block with a Genuine Toyota unit. It started leaking straight away, so something might not be flat (I scraped off all traces of the old pile of gaskets). I'm probably just going to smear a little goop on each surface and hope that will stop it from leaking. I straightened the back bumper and repainted it, but I will probably need to do it again and this time use as much bog as was originally on it as it looks pretty average up close at the moment. I probably faffed around and did other things that aren't springing to mind right now. But the car is currently running and driving well.
  4. Starting to sound like Alex and how he says there are only 2 people in the world who like Vivas...
  5. Kinda tempted to stick some knobbly tyres on it, but they'd be mega bucks
  6. I don't get it. I want to keep my Sprint high and I get abuse hurled at me. I suggest lowering the bug and people want me to keep it high.
  7. I spent today cleaning the yuck off of the engine, giving it a tune up, flushing the cooling system and replacing the pinion seal on the diff. Cleaning the yuck off the engine was a huge job. It looks like the valve cover gasket started leaking about 20 years ago and was never addressed. There was oil everywhere. In some places it was over 2 cm thick! I scraped off probably about 5 kg of it by the end and used 6 or 7 cans of degreaser and a bucket of laundry powder/water mix. After: Before: The pictures really don't illustrate just how bad it was. I should have taken a picture of the underside of the car. The cooling system was just filled with rusty water - not cool! The heater core was almost entirely blocked and it took a solid forty five minutes of flushing to get it flowing freely and have no more orange colour to the water. I filled it with a mix of green coolant and water. The heater works well now. The diff pinion seal was leaking so I swapped that out for a new one. Hopefully it lasts a while. The diff may need to come apart at some point as it has quite a lot of backlash. Other than that the diff is actually really good, it is nice and quiet. I also put new oil in the diff. The engine has a bit of a rumbling sound in it. Could this be main bearings? I'll pull the accessories belt tomorrow and see if that stops the noise. It's definitely not a knocking sound. I adjusted the choke cable and set the idle speed and idle mixture - I had to wind the idle mixture screw in about 15 turns. Whoever set it last time was a numpty, spark plugs were kind of blackish from running rich. This weekend's job will be to tackle the damaged paint surfaces from where brake fluid leaked out in the past. The car also needs some low at some point in the future. It is ridiculously high. Here are some more pictures of the car:
  8. Discussion Thread So I managed to steal a KP bugeye off of an old lady today. She owned it for 20 years and one week. Total KMs are unknown, odo currently says 60,000. She did 30,000 in the 20 years she had owned it. It is a KP60 so should have a 2K in it. I had prepared myself to endure the mega slow that is associated with this fact. When I arrived at the house to pick it up I took a quick look at the engine and the block was red - a bit surprising "aren't 3K blocks red?" briefly went through my mind. The engine was caked in grime so I didn't dig in and look. So anyway, I handed over the cash, gave the old lady a hug (she was pretty sad about losing her baby) and hit the road. After about two seconds I realized that something was up. The car was faster than my Sprint. I kept driving and made it home without any mishaps, gave it jandal a couple of times and enjoyed the speed. I was trying to come up with a logical argument along the lines of "it has small tyres and a 3.9 diff, the Sprint has huge tyres and a 3.5 diff so that will probably make up most of the difference", but I was also thinking "this feels nothing like any 2K I've driven". A reflexive smile formed on my face. I got home and the first thing I did was took a look at the engine block. "Hmmm, there is no lug where the engine number usually is! What about up front?" So I looked at the front of the block and saw nothing except a sort of flatish area of black grime. I rubbed away at it for a few minutes and first I saw some numbers and then I saw a K and then I saw a 3. "Ooooooohhh this explains the power." It would appear that the engine was changed in 1996 and the car was never certified - "Why would you even certify a shitty 3K??!" I hear you say - and somehow the car made it through 40 WoFs without ever getting pulled up for it. I doubt it will ever be pulled up for it so the engine shall stay. The car leaks oil almost as badly as if someone had drilled a hole in it. I'm going to replace as many seals as I can and try to stem the flow. The front guards are a little manky from the old lady driving into cars/walls/people over the years so I am going to repair them - they look to be rust free. The doors have a little bit of rust along their bottom edges, the passenger one looks pretty much fine so I will probably leave it. I'm going to get the rust removed from the drivers door. There is some rust around the hatch window, a very small amount albeit. I'll get this done at the same time as the door/s. The passengers side of the car has been rubbed a fair bit by her driveway shrub over the years so could do with a decent buffing. The seats could probably do with an upholstering. The brake booster and surrounding area need new paint due to some sort of brake leak in the past. It doesn't look like there are any rust holes, or even very much surface rust in the area though. Here's a lame image of the car: It's the same colour as the Sprint, which will make storing paint cans easy. The only issue is that it is a difficult colour to mix accurately. I'll take some good photos tomorrow when I start working on it. I think the very top of the list will be the diff pinion seal and the upper engine seals. And about 30 litres of degreaser. Future (distant) plans: -Restore to as good of a condition as I can -Maybe upgrade brakes and suspension -Cert if I upgrade brakes and suspension I'll most likely have to sell the car before I move back to Auckland so I would like to get it into as good of a condition as possible by November. It might grow on me and I could end up keeping it. TLDR: My girlfriend buggered off to brass band nationals for the week so I bought a car without telling her. She might kill me when she gets back, but at least I have a 3K.
  9. Would the installation of side intrusion bars within doors/frame (completely out of sight) require a cert?
  10. Happened to me once, went and put new pads and fluid in the next day. Not keen on that happening again. /I shouldn't have been trying to keep up with the bugger anyway.
  11. I couldn't find any JB weld when it came to fixing up the grooves in the sealing surface of the washing machine shaft. Had no access to machines so I couldn't turn up a sleeve and run a bigger seal either. Just got the hardest general epoxy I could find and it seems to be holding up half a year later (machine is 14 years old or something)
  12. Is JB weld electrically conductive? I'd never personally do it though...
  13. Seeing how I have been accused of crimes against low, I have undergone an evidential shoe test to prove my innocence. As you can see the car passed with flying colours. Also I pulled the gearbox to bits last week, soaked everything in degreaser and replaced 1st/3rd synchros and all seals/gaskets. Box feels really good now.
  14. Burke's metalworks does a really good bog-free job, $$ but good.
  15. http://www.mrpltd.co.nz/product/kp61-starlet-big-brake-kit/ This would require a cert, right?
  16. Different box, I cross checked the images. I would have deleted and banned him immediately if they were the same.
  17. So do you still recommend Swann?
  18. The springs are corroded in there pretty hard, I wouldn't be surprised if a year in penetrating oil did nothing.
  19. Turns out I've had this car for three years today (date in 1st post was off by a month)... I've had heaps of adventures in this thing and many many more to come in the next year or so. I've pretty much got six months to get it ready. /pic for Frederich
  20. Just a warning about having the nut/threaded portion of the bolt on the underside of the deck is that you will need to use a grinder to remove it in the future if you want to do any maintenance.
  21. And that's what you get for selling your baby.
  22. Probably being held together by some failed head gasket in a can crap
  23. Project I'm working on ATM has 35 kWh, expecting the range to be somewhere around 80-100 km, will find out within a month or so
  24. I have a column in my fuel logbook which has $/100km. I think at the moment I am at about $13/100km. Once got up to about $19/100km when delivering pizza
  25. Around town I get about 6.5 L/100 km if I drive like a granny and put it in 5th as soon as possible. Open road between 5-6 L/100 km, usually driving 100 km/h with a window down. I could probably get it down to 4.5 if I drive 80, but I don't want to hold up traffic/Starlet is pretty boring at 80. These values take into account my odometer error of 7%.
