About Naratechwin
- Birthday 09/07/1996
Gender
Male
Local Area
Christchurch
798 profile views
Naratechwin's Achievements
Advanced Member (3/5)
69
Naratechwin's 1981 Honda Accord - Discussion
Naratechwin replied to Naratechwin's topic in Project Discussion
Whats stuffed with your Accord @brocky41? Keen on the shift knob and front / rear bumper if undamaged. -
Nice! Yellow too? I should have a spare lying around though I won't be able to access my parts pile for a few months (in the middle of moving). Hit up the community on this FB page if you like, a few Kiwis there who would help out. https://www.facebook.com/groups/1Gaccord -
Advice for starting 40yo NOS Engine - Honda EN1
Naratechwin replied to Naratechwin's topic in Tech Talk
Ahh, fair point. Haven't seen it in person yet, just know of it's existence and have mutual agreement on price. Been garaged in a crate on its side the whole time. -
Naratechwin started following Naratechwin's 1981 Honda Accord , Advice for starting 40yo NOS Engine - Honda EN1 , Mk2Marty's bendy Accord and 4 others
Hey all, hoping to get some advice on if there are any potential pitfalls in buying a 40 year old new old stock engine (Honda EN2 1335cc 4 Cyl, similar to the EN1 from a second gen Civic). Presumably these things weren't worn in at factory, so should I be able to just use a high-zinc oil on start-up and treat it as if it were rebuilt? Or should I go through the effort to break it down and relube rolling parts (not sure what happens to assembly grease after 40 years..). Soz for the noob question, I don't want to screw up a new engine. Thanks in advance!
A few months ago I purchased a friends 50cc scooter to see if I'd enjoy riding. I have, a lot. So while I work on a LAMS license and all that I thought I'd get into slowly building the perfect bike for me. I'd always thought the best bike for me would be something a little ratty, late 70's/ early 80's commuter cruiser thing, maybe go for some cafe racer touches. Outside of that an old Honda would fit my norm also. So when I saw this CM400t for sale in Nelson with a seized motor - dirt cheap with rego on hold - I hit the buy now. Trip was a little adventurous, rented a trailer without thinking "wait, how do I tie down a bike on this?", bought some dodgy straps and drove to Nelson from Chch with the trusty Camry. Half way back a strap broke, couldn't figure out how to restrap the bike safely but managed to cram it in the back of the Camry (thank god for un-necessarily large wagons). Drove the trailer home empty. So, it's time to start planning! This thread will follow my (slow) progress working on this bike, starting with finding a donor CM400t or CB400n motor.
- 8
Thanks for the honesty, never approached rust on a car before, so a bit like fish out of water. Yup, on the roof. Assuming cutting out and welding new metal in that gutter would be quite the pain. Will probably try find a local panel beater then and see what can be done.
Heading into my first rust repair, thought I'd seek some advice for a first-timer before I jump straight in, don't want to screw it up too much. Finally built up the self esteem to check out the rust under the weather stripping on my Accord, had some scraping with a screwdriver and looks as if the rust has blown through the first layer of steel in 2 corners, other two corners are surface rust. Currently thinking my best course of action would be to strip back as much rust as I can with a wire wheel on a Dremel, fill the small hole with bog, treat with Por15, primer and throw some rattle paint on top. Want to make sure I'm going about this right, don't want to hide a safety issue or see the rust come back after winter, any advice on products/better methods?
Naratechwin replied to Naratechwin's topic in Projects and Build Ups
Yet another productive week! Spent the weeknights after work cleaning up the engine bay and reassembling the interior, in some spots I'd found almost 1/2 inch thick of oil on the cross-member, so totally worth while! Dropped the motor & trans in Fri evening and spent the weekend putting everything together, gave it a hoon around the block sat evening without the front end fascia on, got many odd looks but one hell of a rewarding experience. Sunday I'd put the last few things together and she ran great! Still need to work out a few minor things (like getting a WOF). Been surprisingly simple working on this ol' Honda, probably the ideal car to learn on, and looking forward to learning more on it in the coming months when I rebuild the original engine and touch up exterior/interior things. -
Done moving! Promptly trashed what was a pristine garage floor tearing apart the Yellow Accord, and had the driveline out by the end of my first weekend here. Found some rust on a chassis rail under the battery that'll need some attention. Will spend the coming week after work sorting out that, fitting out the interior with manual specific bits and hopefully next weekend I can drop in the replacement driveline! -
Sure does, moved the shell w/ rego onto another Honda nut but could get you two in contact as I'm sure he'd be willing to part with the plates. -
Weekend ended well! Got the engine & trans out, a ton of small things needed for the manual swap then finally pulled a pile of parts for other Honda nuts. One of these Honda Nuts was a local and wanted to strip out the body to build up his parts bins, so luckily the rest of the car is off to good use! Now focusing on moving flat and in around a weeks time the yellow Honda comes apart! -
First day in: Think I'm all set to drag out the driveline! Everything disconnected, most parts needed for the manual trans out and bagged. Tomorrows job to disconnect the shifter linkages, all motor/trans mounts and lift it all out. -
@kyteler I wish the loan officer at my bank thought the same way -
Discuss! https://oldschool.co.nz/index.php?/topic/57906-naratechwins-1981-honda-accord/
Had this old Honda for over a year now, bought it from Avengertiger here on OS and had plans to rebuild the motor (from worn out piston rings) in this old girl as my first automotive project: The project started off brilliantly, within a couple weeks I'd given it a hell of a clean and polish, rebuilt most of the rear breaks and had her running around as my weekend cruiser Though as all my plans go, I procrastinated waiting on things to fall into place as the rings got more and more worn, it wasn't until she was vaping up clouds that I was sure the dodgiest of WOF inspectors wouldn't pass did I think of doing something. It was a few weeks ago that I had the opportunity to buy a 5-spd running donor from Waimate. So with a couple hundy in hand I took the drive to pick up a parts car with never seeing the car or knowing much about it at all. Turned out It had been used a daily by a lovely old lady on some long gravel roads for the past decade; having started to rust intensely and failed a previous WOF on a tie-rod end she thought it was time to move it on. One hell of a fun road-trip later I had two old Honda's in the driveway and many pissed off flatmates. This project post starts here; with a week before I'm due to move flat and no space to store the parts car its time to rip her apart! It'll donate Engine, Accessories, a Manual swap (ie most of it's soul) to my beloved Yellow Accord. With minimal experience working on cars I'm sure this'll be an adventure, though I'm itching to get started this New Year 2018! Discuss! https://oldschool.co.nz/index.php?/topic/57907-naratechwins-1981-honda-accord-discussion/
