Everything posted by M.H.
M.H. replied to h4nd's topic in Other Projects
Made a rod holder for the rib, 50mm mandrel bent aluminium tube -
VF Commodore
I use this loctite master gasket, comes in a sweet syringe
What would be the best ecu to use on a v12 with 2 dbw throttle bodies?
So lame needing a cert for fitting a factory brake pedal
Even the old 4 speed btr in the falcons didn't have drain bungs, was a messy job when I did the oil in mine Alot of new cars don't have a drain bung on the sump, oil gets sucked out
Where do you get this information from?
Getting it done pretty quick, has taken me over 2 years to achieve the same amount with my xr600
I do them for $60
- 17 replies
Sand them back, 1000, 1500 then 2000 and then polish them
I don't think the intake manifold will pose much of a restriction. Won't find much info on compounds because people seem to like vnt turbos but they are no good without and ecu control, all modern diesels are compounded now
- 24 replies
- land rover
- disco
(and 3 more)
Tagged with:
I'm using a keihin fcr carb on my xr600, they come in many different sizes, I'm using a 41mm of a crf450. A fcr of a crf150 would probably be a upgrade
Ashcroft transmissions do a heavy duty bearing upgrade for the r380, also fit an oil cooler to it, easy enough to do as the fittings are there it just doesn't go anywhere. 20psi is max what you would run on the standard turbo by itself
- 24 replies
- land rover
- disco
(and 3 more)
Tagged with:
Best way would be to compound turbo it. Use the standard turbo and run an extra 10psi into it with a gt2860 or similar. I was going to do that with my 300tdi but ive gone with an Isuzu 4bd1t and msa gearbox. It's super easy to do and you don't have to make much, will give a far wider powerband than a vnt or single turbo, trick will be to stop the r380 exploding
- 24 replies
- land rover
- disco
(and 3 more)
Tagged with:
What's wrong with Valvoline oil? I run the xd50 but my grandfather ran Valvoline from the 70s on
If it's been sitting you will need to strip and clean the carbs
What model polo?
Price?
M.H. replied to CarolsHusband's topic in Other Projects
Replace the slowest diesel in history with the best small diesel in history -
Do you still have this?
You can get adapters to bolt in vw 1.9tdi engines. -
Could oil pool somewhere and run in once on enough of an angle?
Does anyone have any experience running a 2 stroke on efi?
Force (use to be Chrysler) made a 5cyl 2 stroke outboard with 3 carbs and Audi had single carbed 5cyl
Wat? Where do people get these ideas from?
