Everything posted by h4nd
And then the bent radiator finally started doing wees on the floor. So on recommendation from local chaps, I went to A1 Radiator, who on request did a cheap and cheerful repair, which looks just fine. It's basic up front, so only 20 mins to get it drive-able / testable.
- 90 replies
Then of course CoVid cam, and we didn't need warrants. So I just kind of drive it for a year. Than we needed warrants again, and there was a little bottom cancer discovered. Found a guy, did the thing, got the warrant.
Yeah, so about a year back, I was a dummy in a carpark for long enough to do this. Oops. No one hurt, but
Internet door opener. Comedy gold:
ah, also need KiTTY instead of PuTTY
Why on earth haven't you *nux/*nix supernerds told me about Tilde text editor before now!
I use Librecad to cross check files: https://librecad.org/#download then view-autozoom
Tried vinegar? I had some gunked up carbs that petrol, acetone and other nasty ass solvents wouldn't clean, than later vinegar seemed to work. Weird, but...
Thanks, you just cleared up a mis-conception I had. More here https://www.csselectronics.com/screen/page/simple-intro-obd2-explained/language/en#:~:text=Link between OBD2 and CAN,that it can run on.
Mr @Roman, do you happen to know if brake lights / indicator info come up CANbus via OBD2? TiA
Looks so good (also the car in the reflection)
https://www.trademe.co.nz/a/motors/cars/toyota/listing/2939408453?bof=ncAoTg69
Woss the field current at? (Though I'm unsure what it actually should be). May give a clue to faulty brushes, field windings / alien electron eaters. Youd expect the relay to be on, and current to be climbing. Oh, and check output diodes
Christchurch Meet - Ferrymead Tram Barns (Now Thus 21st Jan)
h4nd replied to EpochNZ's topic in South Island Region
Still keen -
Simple ways to fuck up phish scammers
Who are our other Chch homies might be up for this, @RUNAMUCK @ajg193 @JustHarry @Carsnz123 @NickJ... Who am I forgetting? -
I'm keen, and can bring the OG slam-b-que, or the little charcoal barbie as people prefer -
You may want to work out why it did that before you fit another, short circuit downstream?
I've just realised, per ^ you have crimper for uninsulated. You want the one with the 'w' shape to fold the ends over. I have one of these, and it's OK https://www.jaycar.co.nz/crimping-tool-for-non-insulated-lugs/p/TH1834
Gotta get just the right size/shape jaws. Lots of surprisingly good ones on AliExpress, but can be a little hit-n-miss getting the right jaw set. (Links for you later)
It's probably worth looking up the difference between JIS and Phillips screwdrivers, https://www.webbikeworld.com/hozan-jis-screwdrivers-review/ and finding where your 10mm socket(s) have escaped to.
- 1 reply
I defo got improvement on my repowered SJ410 with a shroud, seemed to stop hot air recirculating / blowing around the edge (even open road, with the fan off). Would a controller that just kept the fans ticking over more slowly (PWM controller?) take the bite / annoyance out of the idling / low-load scenario, and set it up so it only winds up the fans when under load?
Bringin the fan-damily, so your better be on your best behavior.
Paint with sand in it?
