Everything posted by mo999
Having had this thing nearly two years time for an update. Was lucky enough to take it to QCR's "Dirt Masters" and ride it inappropriately. Just removed the front guard and fitted some Golden Boy tyres. So much fun was had, along with @GuyWithAviators on his absolutely ridiculous super stretched Yamaha V50 (Don't try this at home - not a dirt bike :))
It’s a Vanden Plas Princess 1100 my good man
mo999 replied to Agent75's topic in Project Discussion
If it was Craig P that you got the grease gun pump off then it is actually my one that I lent him recently. Let me know when you are finished as I would like it back. -
Yep, those points look terrible, take them out and clean them up and it should be all good.
HI Alex, All I did was locate the existing glow-plug relay (follow the glow-plug wiring back) and just added a trigger wire to the a-fore mentioned push button. In this case that already existed - I suspect someone had the idea before! You can also get aftermarket glow timers that have such fancy features as after start glow as well, but a simple push button will do the job most times.
No at all, I should be around Sat if you want to message me.
mo999 replied to johnnyfive's topic in Upper North Island Region
Spotted this in Wellington, straight back into daily use by the looks of it, plenty of Eastcapes finest mud still attached!- 1724 replies
Yoeddynz and Hannah's HB Viva Wagon Discussion
mo999 replied to Willdat?'s topic in Project Discussion
Hi Alex, I see someone spotted you on FB today Looks like some tried to tag you, but you are not in this group -
Go it home recently and thought it would be rude not to give it a start - only supplied a coil, stuck some fuel in and away it went! Raw Fiat 650 big-block power - it seems to be a sweet runner and will make a nice upgrade from the 500 that I already have.
Long time no update, its been more than a year without any progress on the body, however I am always on the lookout for parts - then this popped up, And thanks to a couple of OS GC's this happened. Thanks to @GuyWithAviators and @Threeonthetree for picking, stripping, packing and sending to me.
This https://www.aliexpress.com/item/Fodsports-RU-Stock-V6-Motorcycle-Helmet-Bluetooth-Headset-6-Riders-1200M-BT-Half-Face-Moto-Helmet/1000004495127.html?spm=2114.13010708.0.0.38624c4dq61ODA But if I was ordering again I would get this one https://www.aliexpress.com/item/VNETPHONE-1200m-Helmet-Bluetooth-Interphone-full-duplex-5-people-at-the-same-time-wireless-intercom-motorcycle/32810906456.html?spm=2114.search0104.3.94.13e54a89DK8FJS&ws_ab_test=searchweb0_0,searchweb201602_5_5722916_10152_10151_10065_10344_5722816_10068_10342_10547_10343_10340_10548_10341_5722616_10696_10084_10083_10618_10307_5722716_10059_306_100031_10103_10624_5722516_10623_10622_10621_10620,searchweb201603_35,ppcSwitch_4&algo_expid=1b59e86c-84c3-417d-a43d-77fcb3849b9a-13&algo_pvid=1b59e86c-84c3-417d-a43d-77fcb3849b9a&priceBeautifyAB=0 As it has a bar mounted remote. -
Here they are!
Just a quick build here, it all started some months back when @GuyWithAviators happened upon a pile of Honda remains and got them dumped at my place. Amongst the bits were these two and with a combined ride coming up with Moped MC and Easties Scooters it was decided I should build the Deluxe frame into something workable, @GuyWithAviators proceeded to send me a pile of parts and below is what happened.
- 9 replies
mo999 replied to yoeddynz's topic in Project Discussion
Sorry, not someone I know. -
Yep we picked up a factory set of twin carbs ($25), ported the head, got the cam ground. Was a bit silly realy it had nothing until about 5000 rpm the it would pull round to 7 K plus. I am from Ashburton so I guess Barry is correct about the number plate. - Can't remember the year -
Sounds like a great project, my first car was an Imp and some years later my mate and I built this one for dirt track racing - then dumped it when finished after selling the very modified engine to another friend for his road car. Seems a waste now as it was a realy tidy one. -
mo999 replied to h4nd's topic in Other Projects
About a year ago my daughter the chef suggested that a hot smoker would be the business. Not wanting to rush these things I started looking for the necessary things to build it from. First up for the heat chamber/smoke generator I picked up a very small charcoal BBQ thing that was barrel shaped. Then a friend gave me a small Morris Lubricants drum. I raided a junk pile for a gas BBQ burner (It was always going to be GAS fired) and piezo igniter. Fitted the gas burner to the charcoal BBQ, joined the two together and added a chimney also reused an old camp chairs legs for the stand. Ended up with this. The smoke if generated but wood chips in a container in the black portion. The females in the house want to call it "morris" however I feel "Nessie" is a better fit looking at its overall form. The only other thing added is a fancy dual channel bluetooth attached thermometer (the chef insisted on this!) We did tried out a beef brisket for the first thing and struggled to get to a high enough temp - we were intending to smoke for 12 hours ended up with 15 and still not quite the internal temp we were after. The result was more like jerky than we wanted - I like it - but not quite right. I reamed out the gas jet and partially blocked off the flue and could now easily get to the required chamber temp ~ 170 deg c Next attempt was a very large chicken - started off by soaking it in brine for 12 hours and then smoking for 3 until cooked - Manaka was used. Looks like this at full noise. Resulted in this, which was excellent very moist and great colour - it was very big chook very happy with the taste.- 1293 replies
- 24
The Barter Barber 1971 Bedford discussion
mo999 replied to TheBarterBarber's topic in Project Discussion
This is such a great project you have set yourself, your attitude seems to fit so well with the Old School way of thinking as well - you certainly came to the right place. I also like the QCR shirt on the bloke at 14:20. All the best for your work -
The other good one is to just start it in gear, go for a drive with your foot on the clutch - give the throttle a few sudden stabs - that always worked for my '71 corolla that had the same problem. -
Is the carb slide up the right way
Cheers for that, Just need to find time to work on it now
Havent realy got a lot more done over the break, I did buy this though. Should help with the glueing back together!
- 65 replies
