Everything posted by AllTorque
AllTorque replied to KKtrips's topic in Lower North Island Region
You look nice today, Alan. Oh, you said condiment. -
Is this solid diff or IRS?
Here is Hilux diff info. toyota-diff-setup When I get a chance I'll look for a paper manual for celica.
What is the diff out of? I can try to find set up specs for you.
It is certainly not a wof requirement in NZ.
If you have a compressor and a rattle gun, you probably should have a proper Jack too.
Palmy Monthly Meet - Tues June 28th 6:30 P.M
AllTorque replied to TimShadboltfan27's topic in Lower North Island Region
You friendly area rep has the power to pin/unpin the thread himself. But I sorted it for you, cuz you asked so nicely. -
I just looked up the coolant capacity so I know how much antifreeze to put in. It holds 15 litres!!
Old junk off. While it was apart I flushed out the block, radiator and heater core. It's all pretty clean really. New stuff on Put on some new fan belts too and replaced a little hose from the water pump to thermostat housing. Once I'm confident I haven't created any new leaks I will put some new antifreeze in. Discussion Thread
- 96 replies
- 5
- buick
- sportwagon
(and 1 more)
Tagged with:
Coming home from Swap Meat the other day, as I was getting close to home, I heard a little belt squeal come and go. When I was nearly there I saw the temp gauge pinned to max, so I gunned it up the hill to home and this happened. Water pump bearing collapsed. Had a little boil up but not too bad. It didn't loose much coolant until the engine was off. So I was straight onto RockAuto to order a new water pump. Pulled off the fan and shroud. Plenty of room to work now. /\ check out the size of that radiator and double thick A/C condenser (I'll get the A/C going one day). \/ Look at the state of it.
- 96 replies
- buick
- sportwagon
(and 1 more)
Tagged with:
Good
AllTorque replied to azzurro's topic in Project Discussion
Bloody better be -
Laying down the lace?!! Shit just got real. You better have big plans to bring this to Wagnats. -
Dear Hemi, I have been enjoying your build thread. I like how you set yourself goals by way of a task list. I can't help but notice an over site on said list. Please add DO A SKID. Kind regards, Roger.
You won't waste away. -
This would be a perfect rainy day room for Wagnats.
Yay BVB is back! -
I'm glad you aren't painting the doors. -
They have them. Do that.
Get out.
All the stress, drama and heartache this car has caused you recently will almost be worth it in the long run. Looks like you're gunna end up with a better package in the end.
Dan's Daily Drivers ~ Disasters and Drudgery.
AllTorque replied to CarolsHusband's topic in Other Projects
Who the fuck is Dan? -
This is rad.
