Everything posted by AllTorque
There are no alerts on the wof computer to say a car is certed.
The park brake turns on when you put the car in park. Fancy
Looks like it is gasless only.
Have you tried Holden?
AllTorque replied to KKtrips's topic in Lower North Island Region
Lovely day for it. I’ll get mine out if you get yours out. (Old car, that is) -
I forgot/ got busy with dad life. -
We fit genuine Toyota pumps all the time with no issues.
With the power of positive thinking.
FWIW Toyota trans service is drain and refill. No pan off or filter replacement.
The drain has a plastic tube inside it. You can remove it with a Allen key and drain some more. The top of this tube is the correct level with the trans in park and engine idling and the atf at 45 degrees C. We just put in the same amount that came out. Make sure you use the correct Toyota fluid. Should be WS, but the fill bung will confirm.
I have used them. You need to make sure the tyre is super clean with no silicone or tyre shine on there. You will need to re-do it often to keep it looking good.
Take them in to CDL’s work and they will tell you everything you need to know. They probably have some NOS pistons tucked up on the top shelf of the smoko room.
Oh, that makes sense. I was trying to figure out how it would spark without the earth.
You would want to remove the master cylinder and calipers.
Seedy Al's Chop Shop - The life and times of all my Crap
AllTorque replied to Seedy Al's topic in Other Projects
Shit that’s rad. Cheap too. -
Is the engine getting up to temp?
Help purchased a 50cc scooter only to find out its de-reg
AllTorque replied to weetbixkid's topic in Tech Talk
Word on the street is her a MR2B form from VTNZ, fill it out correctly, and ride off into the sunset. -
Yes
There is another form they should have given you identifying the areas to be repaired. It has generic car structure pictures that the wof guy should highlight problem areas. Anyone can do rust repairs, but the wof guy will be covering his butt, because he can’t see under the new paint. Ask him if you can take pics of the new metal before you paint it or take the car to him before paint.
If it’s not new it should be ok I guess. Maybe check the valve clearances
