mo999 Posted September 4, 2024 Posted September 4, 2024 31 minutes ago, GregT said: Nothing wrong with a good coat of RTV each end of that manifold. What he said, def sounded like a big air leak on your YT video. 1 Quote
felixx Posted September 5, 2024 Author Posted September 5, 2024 Gasket goo applied Will test tomorrow. Then hopefully chain goes on. I got a new front sproket (15tooth, old one was 13 tooth) and chain. Check over front brakes and im off! 1 Quote
mo999 Posted September 6, 2024 Posted September 6, 2024 On 05/09/2024 at 22:44, felixx said: Gasket goo applied Will test tomorrow. Then hopefully chain goes on. I got a new front sproket (15tooth, old one was 13 tooth) and chain. Check over front brakes and im off! Any progress? you can always check for an intake leak by spraying some easy-start around it while its running and see if it changes the speed. Quote
felixx Posted September 7, 2024 Author Posted September 7, 2024 Sorry I havent got to it. Tomorrow!! Quote
felixx Posted September 14, 2024 Author Posted September 14, 2024 Thanks guys Especially @GregT and @mo999 4 Quote
felixx Posted September 15, 2024 Author Posted September 15, 2024 Next step a nibbi carb https://youtu.be/PH2sXltFlys Quote
felixx Posted September 16, 2024 Author Posted September 16, 2024 Well now its running, it is time to mess with it some more: I am thinking (on @mo999 suggestion) a Nibbi Carb Likely this one: https://nibbiracing.com/products/pe22fl?srsltid=AfmBOoo83kSvNlSMqnZjQRzuJMhVWSJuT4EWAOoEcrafPgWAk-0eMMQT Front shocks will be ordered (likely Ali spec as OEM are unobtanium)Genuine Suzuki Cush arrived in the post, so that will go in this weekend (or wed evening) Horn and rear brake switch arrived yesterday so that is another wee job. Pretty sure even I can get them in for Syd's Run LOL Also I noticed when I apply the rear brakes (foot pedal) there is a 'clunk' in the pedal, any possible sources of this? 1 Quote
felixx Posted September 18, 2024 Author Posted September 18, 2024 New shocks arrived today. can only fit them in upside down. quick google check showed this is ok. Tell me if I am wrong Quick ride up n down street.. nice to ride. Now to get the right size bolts and washers to make it look tidy. From this.. Quote
felixx Posted September 18, 2024 Author Posted September 18, 2024 To this.. 10mm height rise suits my height and stops guard rub. 1 Quote
GregT Posted September 18, 2024 Posted September 18, 2024 On 17/09/2024 at 10:44, felixx said: Also I noticed when I apply the rear brakes (foot pedal) there is a 'clunk' in the pedal, any possible sources of this? Have a look at how the rear brake backplate is anchored. Could well be moving when applied 1 Quote
Beaver Posted September 18, 2024 Posted September 18, 2024 On 17/09/2024 at 10:44, felixx said: Also I noticed when I apply the rear brakes (foot pedal) there is a 'clunk' in the pedal, any possible sources of this? Check the bolt that holds the linkage between the brake drum and the swing arm. 1 Quote
felixx Posted October 9, 2024 Author Posted October 9, 2024 So I got the plastics on her. Much better. The silver suzuki badges are actually clutch cover badges. I plan to add foglights with Amber Angel Eyes in the holes. That way when I put on high beams I will see more 7 Quote
felixx Posted October 19, 2024 Author Posted October 19, 2024 Mocked up the lights today. They could work. But i need to talk to a 3d printer 2 Quote
felixx Posted November 8, 2024 Author Posted November 8, 2024 Bike was clunky as the throttle came on and brakes applied... This was the culprit Quote
felixx Posted November 8, 2024 Author Posted November 8, 2024 Much better. After a short ride I am happier 2 Quote
felixx Posted December 19, 2024 Author Posted December 19, 2024 Still going well. Here it is at Syds Run. 6 Quote
felixx Posted March 12, 2025 Author Posted March 12, 2025 OK so this Pile is still running well but I think it has a bit more to go It currently has a 17mm carb of unknown manufacture/ pedigree/ age on it The exhaust was too quiet So I pick up one of these tonight from a local seller https://www.mbike.co.nz/product-page/nibbi-carburettor in 22mm (I think 24mm might be too much for a 125, what do you all think) And I fitted a rowdier exhaust, but I think the crush washer between the head and header is missing as it backfires from the front of the exhaust so I have one of them to collect tonight Reports to come! 1 Quote
felixx Posted March 13, 2025 Author Posted March 13, 2025 Fitted exhaust gasket. Much happier, no backfiring from head!! Throttle cable snapped as soon as I fitted new 24mm carb Got bike running with new carb plus ether.. hard to start Sounds a lot more responsive once started Will try richening mix tomorrow night or saturday 2 Quote
