KwS's Small Car Shenanigans. Making Altos work.
kws
  • Replies 51
The final lot of parts from Yahoo Japan arrived the other day, so it was time to do some more work.
But first, it was time to clean the little nugget up and take it for its first outing to Cars and Coffee up the coast.
I stopped on the way to catch up with a friend who was also going to C&C, and my wife suggested we grab a couple of photos while we waited.
It's such a cool wee car
I didn't take many photos at C&C, but the Alto drew quite a bit of attention. Had a chat with a fellow Kei (AZ1) owner, and even a GR Yaris owner who was interested in importing a Works himself as a daily.
IMG-510cf90d99c61834f11bbda5c9db4b43-V-0
Back home again, it was time to do a couple of quick upgrades
The first was to finally fit a set of carpet mats to protect the expensive new carpet I had previously fitted. These aren't genuine mats, but the seller makes a strong point that they are "made in Japan" and of very high quality. I tend to agree, they are made very well and are a good fit, and at about half the price of genuine ones, it's a win in my books.
They came with fitting hooks for both front mats to stop them from sliding. I don't know if it's just because my carpet is new, or if an Alto had never had mats fitted if the mounting holes for the hooks will be punched out or not, but in my case they weren't.
I initially thought the mats would mount using the clips the carpet also uses to secure it on the drivers side under the seat, but it uses two other holes in the cross-member which are hidden under the carpet.
In order to access the holes the factory has perforated a couple of little squares in the carpet where the holes are
I carefully used a sharp knife to cut the bottom tab so I could lift the squares up and access the holes
I'm really happy with the mats. They're very plush, and fit well. We're well on our way to luxury car now
The drivers one fits nicely under the Monster Sport footrest
The rear mats don't hook in place, but all the mats have a non-slip backing on them, and they're shaped well to stay in place
Looks a lot nicer than the brown paper I had been using, and a lot more secure for track use next week
The next upgrade I did was to replace the bulb in the high stop lamp in the tailgate with an LED board. I wanted to do this because I wanted a brighter light to catch attention better. The brake lights on the Alto are way down the bottom of the bumper and these days well below the level of visibility of cars on the road. If the high stop light is brighter, hopefully I'll have more chance of someone seeing it instead of rear-ending me.
I bought this off Yahoo Japan, and looking at it, I believe it must be handmade. It's very nicely assembled and looks good. Through-hole components are also unseen these days, it's nice to see.
To fit, first, you remove the cover over the lamp. This just sides away from the glass. This is how you would normally change the bulb. The bulb just untwists from the housing.
Next, you remove the lamp housing from the tailgate, by removing the two bolts. Once removed, I used a thin flat blade screwdriver to carefully pry out the two tabs holding the lens into place. It was easiest to carefully pry between the black housing and the lens
The board just slips into place
It's a tight fit against the reflector and I believe it should be retained in place by the lens clips. If not, I'll need to remove the light and secure the board with some glue.
You can just make out the grid of LEDs through the lens
The wiring is in two parts. The first is the base of a bulb with two wires sticking out of it. This plugs into where the bulb would normally be.
This then needs to plug into the two wires that are coming out of the back of the board. Because LEDs are polarised and can only flow electricity one way, it's best to plug it in and test it before fully assembling it, as like me, you might need to swap the two wires over for it to work
Once I knew it worked, I carefully tucked the wiring in the housing and reinstalled the bulb holder
I then reinstalled the lamp onto the tailgate
It seems quite effective. It was very sunny outside, but hopefully it's more visible now.
The last thing that arrived in this shipment was something I had been trying to buy for ages, but was loath to spend the price for a new one; a Genuine Suzuki workshop manual for the Alto.
I had a saved search on Yahoo Auctions, so as soon as a NOS older version of the manual came up, and confirmed it still supported the turbo models (Works and RS) and was about half the price of a new one, I jumped on it.
One of the main reasons I wanted this was to troubleshoot an issue I was having with my keyless entry buttons, which didn't work (Keyless start works, remote locking worked, but the buttons on the doors were all dead). I knew the basics, but need to know the system layout, trouble codes and wiring diagrams.
Unfortunately as this disk is old, its support in modern systems is very limited. In the end, I had to build a virtual machine running Windows XP, so I could run OG Internet Explorer (doesn't run in Edge, Chrome, Firefox etc).
I did get it running though
Screenshot-2024-01-16-at-10.46.10%E2%80%
Yes, it's all in Japanese, so Google Translate gets a real workout, but the information is all there.
For my particular issue, I navigated to the correct location in the manual and ran through the troubleshooting guide. Most steps refer to Diagnostic Trouble Codes from the Body Control Manual, something I didn't have. I knew it would have a DTC though as the security light in the cluster was flashing on startup.
I tried my OBD scanner, but that wouldn't talk to the BCM. I started looking into all manner of diagnostic tools to run the Suzuki diagnostic software, but in the end, I remembered that for my Swift I had previously had success with a piece of free software called SZ Viewer, which I even still had installed on my tablet.
I fired it up, plugged my ELM327 v1.5 cable in and hit connect
It connected to all modules and even alerted me to two DTCs in the BCM. Success!
I'll look into B150A later, I think that is related to the AC system and isn't causing an issue currently (and isn't lighting a malfunction indicator lamp). B1106 was what I needed to see; there was an issue with the Passengers side antenna circuit. Before now, I didn't even know there was an antenna on the passengers side!
Reading the workshop manual, suggested to locate and inspect the antenna. The system overview shows it on the B pillar behind the upper trim (22)
Screenshot-2024-01-17-at-10.17.37%E2%80%
Digging deeper, it gave specific details
Screenshot-2024-01-17-at-10.16.51%E2%80%
If what I found there didn't fix it, there were a few more steps to follow
Screenshot-2024-01-17-at-10.17.26%E2%80%
I pulled back the B pillar trim and found the wires running up the B pillar
I gave them a wiggle and heard the distinctive sound of the plastic head of a plug rattling freely in the pillar
That'll do it then, it's not even plugged in!
A quick peek behind the upper trim shows the antenna in place, but the connector wasn't looking to flash
Some jiggery pokery with a set of needlenose pliers allowed me to remove the antenna from the two clips holding it in place. This confirmed the part of the connector that should latch to the plug was completely missing. There is some "damage/modification" to the B pillar trim in the area, so suspect it got damaged during cage install and never fixed.
That ain't nothing a ziptie can't fix though
Once clipped back into place, I shut all the doors and pressed the button on the drivers door. "beep" *clunk* - All the doors locked and the mirrors folded in.
I tested all the buttons and all worked perfectly. Very happy with that fix. I might have stumbled on that wire by accident at some point, but the manual and SZ Viewer were the real heroes here.
Now that all the nice clean hands stuff was done, there were two jobs left for the day.
I jacked the car up and put it on four stands.
The first job under the car was to drain a small amount of gearbox oil, and add some Redline friction modifier to hopefully help the Cusco LSD be a bit more civilized when it's cold. At the moment it clunks, bangs, binds and sounds like the axles are in bits. I know this is normal to a degree, but it'd be nice if it was slightly lessened.
I drained off some fluid, and using a syringe added a minimum recommended amount of additive, 30mls (or 1oz). I don't want to over dose the oil and risk the LSD slipping too much and not working.
A quick drive (including some tight circles in a carpark) shows it might be a little better already, but I need to get the additive cycled around the box a bit, so tomorrow's drive to work will be interesting.
Finally, I wanted to give all the brakes a quick flush. I know for compliance the pads were replaced with RDA Phantom Ceramic pads (the same I'm running in the Jazz), and the fluid looks clean, but I wasn't sure if they had also bled the rear brakes. A quick vac with the bleeder, and now I can have a bit more confidence knowing it's done. The old fluid wasn't worrying, so maybe it had been done.
So for now, until a couple of other specific parts arrive from Japan through the local dealer, that's all I have for it.
Next Monday will be the little nuggets first outing on the track, so I'm both excited and nervous about that. Hopefully, it all goes well, and I can beat some of the times I put down in the Jazz last year. We'll see.
  • Like 8
Chances are, this code is because you were in the shed when you scanned the BCM, so there is no sun on the solar sensor.
Good point, it was about 10pm and outside lol
Removed the tow hook the other day and fitted the blanking panel. The towhook will remain in the boot once I have the insert to store it. It tidies the front up a bit, but i do kinda miss how it looked.
On a side note, now that the auction results have dropped off the system, the rusty 4WD Alto I bought in Japan has resurfaced at a dealer in Japan for a shade over a million Yen (more than I paid). Looks like they gave the underside another coating of underseal, and fitted the white "summer" wheels, which were missing from the car when it was inspected after I bought it...
  • Like 6
It's been an interesting few weeks. I had a scare in the Alto, and more parts arrived.
The weirdness started when I was taking the Alto to work the other week. I jumped in, started it up, and all was normal. I'm cruising along, jamming to some tunes, and hit the usual start stop traffic. I'm just crawling along... And BAM, ALL the dash warning lights suddenly light up and start flashing. They flash a few times and then the majority turn off, leaving only the Check Engine and Stability Control warning lights lit.
I'm worried, will the car suddenly die stuck in traffic? Is the car about to asplode? I've never seen all the dash lights flash like that. I quickly jump off the highway at the next exit and crawl the car home.
It was running fine, no misfire, no smoke, no leaks, nothing. Just the lights.
I made it home fine, swapped cars and left it to think about what it had done.
After work, I plugged in the tablet and fired up SZ Viewer to scan the codes. Ah yes, I think I have a couple of codes. None were current, but nearly all modules at at least one code.
Reading into the codes, they all centered around one thing, the loss of CAN communication with the ABS unit.
I checked all the modules and they were all the related codes, so I saved screenshots of the codes for later and cleared all the codes in the modules. Nothing came back.
I've driven a few hundred KM since, and haven't had any issues, so hopefully it was a once-off and not an intermittent CANBUS issue.
I did have a quick look at the ABS module and it looked normal, so I gave the plug a wiggle and left it
While in the engine bay, I forgot that I hadn't shown my awesome duct tape duct.
For whatever reason, either the intake rubber intake or the fibreglass duct are too short and they don't really meet up, leaving a large gap between and around the two. I made the duct tape duct before trackday to try and encourage more air into the airbox rather than slip out around the smaller rubber intake. Its fully enclosed and seals the two parts together.
It withstood the trackday heat and is still there. I might look for a proper solution one day, or maybe not.
The other day I finally had some bits arrive that I have been trying to get for months. Before Christmas, when I first got the car, I tried to order these bits through the local dealer. They asked Suzuki NZ, who asked Japan, and were advised they could be ordered, so we placed the order.
Japan then proceeded to ignore the order and not process it. After a couple of months of chasing it, I cancelled the order.
I enquired with Amayama, who I have been getting the majority of my genuine Suzuki parts through, and sure enough, they could supply and at a lower cost.
Finally, those parts arrived. What are they? Well, the main one was the massive polystyrene insert that sits in the boot and gives me a proper boot floor. Without it, the floor of the boot is much deeper but tapers and makes it kinda useless for carrying anything in.
The insert just slips into place
All the shaped spaces in it are meant for things like the jack, tyre iron and flat tyre goo kit. I have none of these, so all it is used for is my tow hook
I would like to find a water bottle for the intercooler spray that fits into one of the spaces too...
Having the block in place means I could reinstall the coreflute "floor" and carpet. These are retained with two special clips with little pull tabs on them, so you can access the tools under the floor
It's a kinda dumb thing to be excited about, but I can finally use my boot.
The other thing to arrive was the LH and RH front A-pillar trims. The LH side had a big crack in it, and the RH side had a bunch of holes from when the Japanese owner had a gauge pod fitted there.
To remove these trims, all you do is pull down the door seal
And pull the trim free, starting at the top.
It's hooked into the dash at the bottom, but easy to pull free. Refitting is the reverse, hook it in at the bottom and then push the clips into place. Refit the seal, and you're done.
I've got a couple of other small things on the way and then that should be most things sorted. It's crazy how well priced genuine parts are for these wee things. I'm paying the sort of prices I would normally pay for secondhand junk on Facebook, for brand new parts from Japan.
Future thoughts are an oil cooler for the engine, an SWK intercooler and water sprayer, and maybe some half-down lowering springs. All in good time, and depending on cost.
  • Like 8
Re dash lights, check your alternator and battery. Often when there are codes everywhere it causes by low voltage. A lot of modern cars will turn off the alternator when idling until there is enough electrical load.
I had a similar problem with my volvo.
It had a ECU controlled alternator, and it had been replaced with a slightly different alternator at some point prior to my ownership.
Apparently it would overcharge and the car would shut off the alternator. So every now and then, the car would light up like a Christmas tree and be bricked, with the wipers running on full hah. (My only car ive ever used AA+ on, twice!)
All modules would throw a code, and it was to do with canbus connection being dropped.
The guy i sold the car to found this out (i sold it bricked as i had no idea what was causing it). Fitted the correct alternator and it was all hunkey dory.
