Beaver Posted May 14, 2023 Author Posted May 14, 2023 New tyres and tubes fitted up, and seat is with @64valiant getting some much needed love. The seat base was quite bent which was kicking the tail up too high making it look like a banana, and someone had a go at being a DIY seat builder and upholster with pretty poor results. Not only did it look terrible is was very uncomfortable. Will look and feel much better when said and done, and give the bike the nice flat lines it deserves. Had some fun with some seats Greg had in stock. Turns out a mudbug seat fits quote nicely! 1 Quote
Beaver Posted June 5, 2023 Author Posted June 5, 2023 As per previous photos, fixed the seat courtesy of @64valiant shit it looks good. My backside appreciates it as well. Also a small today up on the back using left over v50 bits (got rid of the big square plate mount and the oversized tail light bracket. Is now road legal and period correct plate style and stickers etc to round it off. Quote
Beaver Posted July 5, 2023 Author Posted July 5, 2023 Have been commuting on this every day for the last month or so. Great way to start and end the work day for sure. Only had one hiccup on a wet day when it lost spark. Once it dried out it was fine. Other thing that bugs me was it leaks fuel through the carb and out the inlet when sitting. I turn the fuel off anyway but still. So stripped the intake down (after adjusting the carb floats) and resealed things back up. One of the mounting holes for the intake is snapped off, and the precious owner just good it up. Instead I used a big washer to clamp it down. Seems to have done the trick. Quote
Beaver Posted July 5, 2023 Author Posted July 5, 2023 And got a few extra HP by replacing throwing cap screws at everything Quote
TimShadboltfan27 Posted July 6, 2023 Posted July 6, 2023 50 minutes ago, Beaver said: Only had one hiccup on a wet day when it lost spark. Once it dried out it was fine. Same on the RX125. Happened a lot on east cape and was super annoying. assume water getting into points gubbins and turning everything british? Would be interested to know if you find a solution that isnt just 12v cdi conversion Quote
Beaver Posted July 6, 2023 Author Posted July 6, 2023 30 minutes ago, TimShadboltfan27 said: Same on the RX125. Happened a lot on east cape and was super annoying. assume water getting into points gubbins and turning everything british? Would be interested to know if you find a solution that isnt just 12v cdi conversion The coil on this sits up under the tank and gets spray from the wheel. The spark lead and cap are also in the firing line. So I think its one of those causing issues. Plans are to replace the original cap with modern one (I had water issues on my v50 lifan where it woudl start running like shit as soon as it was raining/the road was wet. A good quality NGK cap with a rubber seal solved the problems 100%), and look at a way to protect the coil a bit better from water. Quote
GregT Posted July 6, 2023 Posted July 6, 2023 Once upon a time you could get a rubber condom for the business end of a coil which kept it all dry. Just slather RTV over it all for the same effect. Quote
HighLUX Posted July 6, 2023 Posted July 6, 2023 Spin the coil 180 degrees so the lead is on the trailing side and pack the plug boot with grease. Its ghetto but it works Quote
Beaver Posted March 5, 2024 Author Posted March 5, 2024 Anyone interested in buying this? Its not getting used enough and I could really use the cash to fix my other things. Moped rego, nice and reliable for around town nangs. 1 Quote
Beaver Posted April 1 Author Posted April 1 1 hour ago, Rudy said: Is this bike still for sale Negative. Well not by me anyway. Had been sold and unsold again since I owned it. Quote
Haydog Posted June 8 Posted June 8 ah man why did i have to find this post 3 yrs too late 😓 bike looked beautiful Quote
