  • Replies 42
There's not that much to strip down, but I did that and out everything not aluminium in the hot tank to strip the probably lead paint off
I actually have the frame sitting in a big one as well, there's 2 spots that are brazed which won't like it, but il just tickle them with the mig welder later
The tray is savable, but for the time and effort to strip all thr paint, cut and weld patches I decided not to bother. The frame has a hole in one section, so that but will get repaires
My tricycle was an Empire. I know nothing about them. I do remember undoing the screws which held the rear mud guard support on. And it flopped around quite badly after that.
Also I remember that plinking one foot in the tray, and trying to ride it like a scooter resulted in me doing a face plant and grazing my chin.  42 years ago and I still remember it.
Pain the best teacher.
It's just a kids trike, let's not get too crazy
Wait, no not like that
These are the headset "bearings" if my memory of 30 years ago is correct, there should be an oil soaked felt washer between them.
The bottom one was nickel plated, the other two, hard to say, very rough surface so I don't think they were. However they will all now be nickel plated
I will also replate the bars, and probably do the wheels
Started nickel plating
Really I should set up a bubbler and add some surfactant to get a nicer finish. Goes like that cos the tiny bubbles cling to the surface so you get little craters.
It's fine tho
 Wheels painted
I panel glue urethaned the old tyres back on and ran a screw through the join. Will see how that goes
Tried my hand at some gold leaf lettering, boy that shit sticks to everything.
And added an Indian coin for a head badge.
Anna's birthday in a couple weeks, just got to plate the bars and it's done.
Supposed to have hubcaps on the rear wheels, but I only have one, will think about pewter casting another if I get time
  • Like 9
13 minutes ago, GuyWithAviators said:
Looks lovely. Will that motor fit in the tray? Might handle better than an ATC70
I have a weed eater motor ready to go on, power one wheel at low speed.
