Jeffs_Emporium Posted July 12, 2021 Author Posted July 12, 2021 Clutch showed up today. Previously I posted the 4agze 225mm flywheel but I opted for the smaller 200mm as all the clutches were so expensive for the 225mm I used a wet piece of limited edition Freyas sourdough to remove the old crank bearing. The ae86 disc didn't fit as the spline was too small but I checked the original 5k disc and it was a next to new exedy also so a quick swap over which I then saw I could have just used the whole van pressure plate also. Oh well. 6 Quote
Jeffs_Emporium Posted July 12, 2021 Author Posted July 12, 2021 Left over toyota SST from my 1gge fiddling for holding crank while I torque pulley 7 Quote
Popular Post Jeffs_Emporium Posted July 12, 2021 Author Popular Post Posted July 12, 2021 Easy does it lots of lifting van, repositioning scissor jack holding gearbag and again with axle stand for missing wheel. Rest on seat frame to reposition again 13 Quote
Popular Post Jeffs_Emporium Posted July 12, 2021 Author Popular Post Posted July 12, 2021 Fire in the hole four bolts half wound in from bellhousing side and rest onto mounts. you can just see in photo sump is fouling on the removable stone guard which is holding engine up. Test fit of drivers half of bonnet shows its fouling by hopefully the same amount it needs to drop down. the untrained eye says the carbs will fit. fingers crossed 34 Quote
Popular Post Jeffs_Emporium Posted July 13, 2021 Author Popular Post Posted July 13, 2021 Another hour fiddling this afternoon. Dropped the stone shield and the motor dropped down. Test fit drivers half bonnet and it's still fouling. Might try @BlownCoronasuggestion of offset and maybe thinner engine mount to get it. 20mm drop would be perfect. Carbs look like they will go also, might relocate the coil to passenger (maybe not since exhaust?) If I can sort the drivers half of bonnet passengers side will definitely work as its raised again 11 Quote
Jeffs_Emporium Posted July 16, 2021 Author Posted July 16, 2021 Picked up some coby looking headers after watching @kprlatest video 6 Quote
Popular Post Jeffs_Emporium Posted July 16, 2021 Author Popular Post Posted July 16, 2021 Test fit in the engine room 10 Quote
Jeffs_Emporium Posted July 16, 2021 Author Posted July 16, 2021 They hang very low oem cast manifolds are a pain to find but look more suitable unless I shorten these 7 Quote
Jeffs_Emporium Posted July 18, 2021 Author Posted July 18, 2021 Test fit carburetors Again just fouling on seat but thinner engine mount will remedy. Rear two trumpets are basically touching the sheet metal diving battery area and engine bay, wondering if I could use a die to pull two 60mm holes through with a dimple die leaving a lip for rigidity in the panel? Picked up a starter motor yesterday and installed, just noticed the headers are basically touching the solenoid, is this usual? 9 Quote
Jeffs_Emporium Posted July 18, 2021 Author Posted July 18, 2021 Finally settled on a linkage kit that I liked from med-engineering.co.uk with a bit of luck I can retain the factory throttle cable. Reasonably priced at $216 delivered and comes with the balancing lever to join second carburetor. The Carter Fuel Pump has just shown up from Rock auto which has come with these handy instructions on installing Is the check valve linking pull hose to push hose acting as a recirculating return when the bowls are full? Another peice of advice I'm seeking is a recommendation for the driveshaft shortening in Auckland as 'Drive In' in New Lynn have said their driveshaft guy is off for 8-12 weeks with a hip replacement 9 Quote
Popular Post Jeffs_Emporium Posted July 29, 2021 Author Popular Post Posted July 29, 2021 I did not complete the two week challenge but I'm still chipping away. Aidan at Pine Engineering sent me these photos of the br-x completed last night @BobbyBreeze was kind enough to lend me a centre cap to replicate also which are just off being anodized I have a new set of Yokohama A539 in 175/60 and 185/60 at home ready to go also 31 Quote
Popular Post Jeffs_Emporium Posted August 4, 2021 Author Popular Post Posted August 4, 2021 Advan spam 16 Quote
Jeffs_Emporium Posted August 4, 2021 Author Posted August 4, 2021 Had a win on the illusive 4age engine to gearbox braces last night on yahoo. I'm still torn about what to do with exhaust manifold, i have spoke to someone about shortening the headers and it looks like the pipes are too close to each other to fully weld. A factory ae86 cast manifold is going to cost me about $400 from Japan Or fujistsubo do a few options like this 4-2-1 stainless which I could trim or remake the lower section Or this 4-1 also fgk stainless which looks like it joins higher up from the secondary pipe they show in photos. Both of the fgk are around $¥75,000 so not cheap but probably a bit cheaper than having a set made plus the logistics and time of transporting vehicle 5 Quote
Popular Post Jeffs_Emporium Posted August 5, 2021 Author Popular Post Posted August 5, 2021 Linkage kit installed I need to shorten the balancing tab between carbs to fit the front one on. I need to grind down the boss on the second runner so the carbs can slide back, would also like to shave 5mm off both surfaces of manifold to gain 10mm clearance from carbs to van body (currently both flanges are 13mm thick each and overall manifold 54mm thick. 16 Quote
Popular Post Jeffs_Emporium Posted August 10, 2021 Author Popular Post Posted August 10, 2021 Centre caps arrived 13 Quote
Popular Post Jeffs_Emporium Posted August 10, 2021 Author Popular Post Posted August 10, 2021 Tracked down an ae86 cast manifold and downpipe locally also 13 Quote
Popular Post Jeffs_Emporium Posted August 11, 2021 Author Popular Post Posted August 11, 2021 Received a used hyperpak in the mail today to control spark with the original 4age dizzy meaning I don't need to run ecu or the massive harness that comes with it 14 Quote
