I do play with pinto stuff as well.
And this setup if you havnt read some old posts is a setup I qas making for my nephews mk5 before we decided efi and turbo is much better... the process the bits were all siting around and I would like to see if it worked.. ....so I bought the bits off him.
I had the 50+ years old carbs and the supercharger vapour blasted .
Had a mate 3d print me a manifold to bolt 2 SU HS6 carbs from a p5b rover to the toyota sc14.... once we had it finalized we sent it off to a company in aussie to be made out or appropriate material that isolates the carbs from the SC and is fuel,oil,heat resistant.
Swapped a smaller pulley on (thanks again @BlownCorona for that)
And a pulley the right size i got at pick a part  bolted to a sierra crank pulley and a 6pk belt.
I do have a carb rebuild kit turning up this week hopefully...
Side entry dizzy cap20241201_152356.jpg.e92016828277fb81055d7515bb183264.jpg
The cool weeee manifold
I jave a test bed I've made to run a pinto on (as I say I enjoy playing with them) so ill be able toasleep if I can get it all running...
It woild only ever fit in a mk3 4 5 cortina or rat rod... so i might just sell it all once working or just keep it as an ornament 😆
  • Replies 140
