cletus Posted June 3, 2019 Share Posted June 3, 2019 Should be a tag somewhere (under the seat or on one of the pillars maybe?) with an axle code on it That might help? 1 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 3, 2019 Share Posted June 3, 2019 Is the diff Salisbury or banjo? On that tag the HJ 52 would be the axle HJ is.probably a Hitachi diff (so it.would be banjo) and 52 would be 5.2:1 ratio 1 Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 3, 2019 Author Share Posted June 3, 2019 Holy shit!!! I reckon there's a tag like that up high on the B pillar. BRB *dons gumboots and 12 layers of clothing P.S: it's a banjo 2 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 3, 2019 Share Posted June 3, 2019 Theres an H230 diff (230mm crown wheel) and an R230 There's a solid axle version of the R200 called a C200. So not impossible there's a solid version of the R230 too. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 3, 2019 Author Share Posted June 3, 2019 Cletus, you're a fucking genius. Better than chess and sandwiches with all the hot girls at Mensa. I have no idea why I didn't look at that tag. I'm off to Google now 5 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted June 3, 2019 Share Posted June 3, 2019 If it's open you could use one of these- replaces the spider gears and pretty cheap https://ruggedrocksoffroad.com/nissan-hardbody-lock-right-locker-by-powertrax-1986-1997-h233b-31spline-p-3653.html 1 Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 3, 2019 Author Share Posted June 3, 2019 Ta. I saw those Spartan lockers when searching online yesterday. It's good to know (from the chassis plate) that my truck should have a ~4.3:1 rear diff with the same crown wheel diameter as found in some Patrols, but I'll need to look inside it to see if it has a LSD clutch pack. There's heaps of rusted out Safaris and Terranos here so used parts should be easy to get locally. My old Patrol had a factory locker (air/vacuum operated). I may get lucky enough to find one of those in a paddock... Here's hoping. 1 Quote Link to comment Share on other sites More sharing options...
Mof Posted June 3, 2019 Share Posted June 3, 2019 ^I tried one of those in the Samurai (lockright), it was shit, undriveable. Constantly unlocking either axle at random. U-turns were impossible, driving a straight line was impossible tbh. Even the diff shop couldn't get it to work. (There's a bit of a story here, but spam). Don't imo 3 1 Quote Link to comment Share on other sites More sharing options...
Mof Posted June 3, 2019 Share Posted June 3, 2019 I think I remember terrano rear diff being the same as safari front diff, lsd in terrano rear... Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 3, 2019 Author Share Posted June 3, 2019 Apart from not being able to turn or drive in a straight line was it good though? LOL!!!! 2 1 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 4, 2019 Share Posted June 4, 2019 LSD checking. My method is jack it up make sure it’s neutral and handbrake off. get a friend to hold one wheel. You turn the other. If you can feel drag that’s more than just open diff and prop shaft weight drag then it’s limited slip most small trucks are just open. Chathams sounds amazing. What do you do down there? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 4, 2019 Share Posted June 4, 2019 Just tear off a corner, jam it under your tongue and wait for an hour or so. If the lagoon starts to look like rainbows, then there's a good chance it's LSD. / do a skid. As others have said, if it's a clutch type LSD (or a viscous for that matter), both wheels should rotate forwards when you spin one side. If the diff is worn out, it should still have some level of grab, but a person on the other side of the vehicle will be able to hold the wheel still. People have mentioned that torsen/helical diffs spin the wheels in opposite directions. It's unlikely that a truck like yours would have a torsen, but there's a test for them too. Jack the rear of the vehicle up, spin the input shaft and try to hold both of the wheels still. If it's torsen, both wheels will spin forwards. This only happens when there's torque/load applied to all three shafts (input and both outputs), if you stop applying torque to one input/output it will unlock. 7 Quote Link to comment Share on other sites More sharing options...
SiRge Posted June 7, 2019 Share Posted June 7, 2019 Or do a quick heli on sand. You'll see how many rippems were given 1 1 Quote Link to comment Share on other sites More sharing options...
