dmulally Posted August 16, 2021 Posted August 16, 2021 38 minutes ago, kws said: Isn't the is200 box just a j160 altezza box? Can you not run a standard sender? Honestly no idea. I'm willing to try anything though and would need a matching speedo. Quote
ThePog Posted August 16, 2021 Posted August 16, 2021 On the Dynafari I got an Isspro speedo that could take pretty much any pulsed input signal, there is a bank of dipswitches that you use to calibrate it. Im pretty sure you could just run a magnet past a coil or hall sensor and it would work... 1 Quote
Raizer Posted August 16, 2021 Posted August 16, 2021 6 minutes ago, dmulally said: Honestly no idea. I'm willing to try anything though and would need a matching speedo. W5* drive should go straight in. 1 Quote
dmulally Posted August 16, 2021 Posted August 16, 2021 3 minutes ago, Raizer said: W5* drive should go straight in. Like this? https://www.trademe.co.nz/a/motors/car-parts-accessories/toyota/electrics/listing/3222354539?bof=FLF9xzQ0 Quote
HighLUX Posted August 16, 2021 Posted August 16, 2021 Nah needs to be from a RWD toyota gearbag like a W55 or even a G52 from a hilux would work. @Roman should know the ins and outs of mechanical drives for a J160 A bolt in factory option thats not a modded electronic drive should solve the cable eating issue and negate the need to get all fancy with electronic drive. Keen to see how you made shift linkages on the gearbox work in a van too 2 Quote
dmulally Posted August 16, 2021 Posted August 16, 2021 12 hours ago, HighLUX said: Nah needs to be from a RWD toyota gearbag like a W55 or even a G52 from a hilux would work. @Roman should know the ins and outs of mechanical drives for a J160 A bolt in factory option thats not a modded electronic drive should solve the cable eating issue and negate the need to get all fancy with electronic drive. Keen to see how you made shift linkages on the gearbox work in a van too Honestly I think it is just new cables being a poor fit inside the liner. The original one was a lot easier to spin in my hand than any of the new ones. Cheers for the heads up though. Next task is to actually find one. I'll scooch under there a little later and put some pics back up here for ya of the linkages. It is all commer at the front and the difference in throwing distance is about 250mm. No kidding. Quote
dmulally Posted August 16, 2021 Posted August 16, 2021 Here is how the linkages work. Three rose joints and 7 gears including reverse. The speedo sender below is just taunting me at this point. 5 Quote
dmulally Posted August 18, 2021 Posted August 18, 2021 Does anyone know if this will work with an Altezza box? Edit: Ignore that. It'll be this. Quote
dmulally Posted April 13, 2022 Posted April 13, 2022 On 18/08/2021 at 13:14, dmulally said: Does anyone know if this will work with an Altezza box? Edit: Ignore that. It'll be this. Turns out it was that after all and I can successfully report back that it all works. For anybody desperately searching the internet that happens to stumble upon this post, the speedo I used was this: https://www.shopsaas.com/saas-speedometer-0-220-kph-3-1-2-in-dash-black-muscle-sg31632 I stuck it in the middle of the dash and it is rather bright. 1 Quote
dmulally Posted September 24, 2024 Posted September 24, 2024 New year. Different shitbox. I've just completed a diff swap and the speedo is way out. As I want to piss the running gear off for something more farm friendly, rather than pull the gearbox back out I might as well do the speedo nonsense now. Does anybody happen to know how to set up a VSS from a hall effect sensor reliably? I was going to use this. Which takes a GPS or VSS. In fact it looks like it needs to GPS initially to calibrate. For the VSS it says: Acceptable signals range from 1-100V. 500-250,000 pulses per mile. For two-wire speedometer sensors: connect either wire to the Speedbox’s VSS wire, and connect the other wire to common ground. The two wires can be reversed. A quick google and I found a three wire hall effect sensor. Anybody got any tips or tricks for getting this to work? Cheers Quote
