~Slideways~ Posted August 16, 2019 Author Posted August 16, 2019 I have always found the stereo to be under powered, its a Panasonic jobbie rated to '50wx4' but it has always sounded pretty crap and complete lack of bass. The stereo was in it when I bought it, a couple of speakers didn't work, there are 6, one in each door (including rear barn doors). When I did the rust on the drivers door I found the speaker was a decent spec thing. The barn doors too. The rear doors have fusion speakers but they are damaged, the covers came off and the cone was touched by my boy I guess. I have been wanting to put an amplifier in but I didn't want to use a 24-12v power reducer because it just annoying complication and in order to power an amplifier it'd need to be a pretty high rate one. I do have a 40A one but that is all used up by the water/meth injection pump which is 12v. 24v amps don't seem to be common so I never bothered over the years. Ali Express to the rescue though, I bought one of these 12-24v TPA3116 2.1 tiny bluetooth amps. $32USD delivered. Worth a try? The fact that I Icould run it straight off 24v was the biggest thing. It arrived and it's fckn tiny, how can this do the job? Why are 'normal' 12V amplifiers still so big? I assumed it would suck. The aliexpress reviews were good. Someone mentioned that there was no thermal paste on the heatsinks. So I took them off and yep, nothing. So I added some, can't hurt right? I then pulled a part the dash and stereo junk. Man the install was pretty iffy and messy, quite a few of those horrible push on splice things, hate them. I also found that a couple of the stereo output wires in the terminal screw block type things weren't even screwed to the wire core lol....it was probably pushed in far enough to touch the other wire anyway. See the pink wire with the indentation, quality work. The manual for the bluetooth amp jobbie says it draws 3A. WTF, that's nothing?! This thing is going to suck. Temporarily installed after figuring out which wires go to each door and see if it was even powerful enough. You can see how small this thing, it's smaller than the ashtray slot. Which is where I'll put it. Tried connecting to bluetooth with my phone, no problem. Anyway, with just the two front door speakers connected, it has good volume. Better than the Panasonic can produce, pleasantly surprised. The amp control knobs are a a bit weird. The red on is for overall volume, but you also have a bass volume and treble volume (and freq adjustment for each). So you have 3 volume knobs, weird. With 24V it should be able to supply the full 50w (rms I think) per channel (only 2). At 12v it would be less, 20 or something. So I tried it with the two good back barn door speakers connected as well, so the amp is powering two speakers on each of its two channels. Sounds pretty good, no distortion and the treble frequency adjustment makes a big difference. Bass freq changes weren't as noticeable. I have an old Fusion subwoofer and box collecting dust, it came with an old runabout about 7 years ago. I used it in that car with some cheap amp that also came with it, I remember it made good bass but it seemed to have interference at lower volume...vague memory. I assumed it was the cheap brand amp. So I thought I'd try it using the 100w little amp's bass output. How the fck can this little thing power that? It's like an 1/8th the size of the old amplifier it came with. Holy crap, very impressive bass! BUT if I have the volume low it seems like the subwoofer is trying to produce sound and it comes out sounding like a broken speaker. No matter what I do with the frequency setting on the amp it doesn't stop it. At higher volume it sounds great, especially for $32USD. I'm wonder if its the subwoofer itself, it MAY be the same sound I remember it producing in the runabout jobbie. Otherwise it has to be the aliexpress amp. Which to me seems unlikely since the other channels sound fine. I haven't installed it properly yet, the amp doesn't have an on off switch so I need to figure out if I can use a switch (at an apparent 3A draw...) or wire in a 24v relay with the IGN on power. Other than the subwoofer issue, its bloody impressive for a tiny thing, is it just because technology has moved on? I mean old amps used to have 3 x 25A fuses? EDIT: what I think I'll do is test the subwoofer output with another speaker and see if I still get the low volume noise. The subwoofer is 12", if I had to buy another one I think I'd get a 10" for faster response. I listen to stuff which would need that. This 12" seemed to keep up okay but I assume a 10" would be better. Or maybe split the 100w to two 6x9's and try put them in the rear doors? 3 Quote
~Slideways~ Posted August 16, 2019 Author Posted August 16, 2019 Oh yeah, it also got its wof after de-cancering it a bit. 2 Quote
~Slideways~ Posted September 13, 2019 Author Posted September 13, 2019 Got this jobby installed a few weeks ago, will mostly use bluetooth with my phone but have also wired the stereo output into it so I can use radio/cd/usb etc. Pretty sure the subwoofer is blown, tested with a old shitty 8" thing from garage stereo and it didn't do the crackling thing at low volume. Will look out of a 10" of some sort for a decent price. Looks pretty cool in the dash where the ash tray was. 3 Quote
~Slideways~ Posted June 2, 2020 Author Posted June 2, 2020 Stupid driver seat frame has needed fixing twice, it’s a shit design. I’ve wanted to fit some wrx seats for ages, have had some gathering dust for ever, so put one in. Fits better than the old no name brand ones (were in it when I bought it) and is more comfortable. Win. 3 Quote
~Slideways~ Posted January 8, 2021 Author Posted January 8, 2021 Took this off the road to deal with the rust on drivers side of the roof, it was worse than I thought under the bog job that the previous owner had paid a lot of money for.... that was probably 7-8 years ago now so I guess it lasted a while. I decided to go all out and cut any trace of rust out of the roof then paint the whole thing. Condensation is what gets to the roof skins on these so I sprayed lots of wax anti rust stuff in everywhere. Decided to do something a bit different and paint the roof with 2 pack textured stuff, like Raptor liner but I used Novol Cobra stuff. In theory it'll hold up to scratching branches etc, some sound deadening and I don't know...it looks cool? Also stripped the front bumper back to bare steel and coated that too. This is just after spraying it so its a bit less glossy once dried, in person it turned out pretty cool: Also made up some brackets to fit the passenger WRX seat, Murphy's Law meant the last bloody bolt was pre-stripped, it'll have been like that the whole time I've owned it, no way of getting it out so ended up having to cut it open to get to the stripped nut inside and weld it back up. 4 Quote
~Slideways~ Posted January 8, 2021 Author Posted January 8, 2021 17 hours ago, rumrum said: g pics don't werk Should be good now, was working with Google photos at first then it stopped. Not sure why so uploaded instead. 1 Quote
~Slideways~ Posted June 7, 2022 Author Posted June 7, 2022 Took this out to the south coast to go see some seals. Saw seals: Found a water fall: Nice. 7 Quote
~Slideways~ Posted February 20, 2023 Author Posted February 20, 2023 Man, I must have had this a decade now? Failed recent WOF on a few things. Front Panhard rod play, it's an aftermarket adjustable 'Toughdog' brand one and was a little worried about sourcing bushes. But thankfully I found that they use Nissan genuine ones, which multiple sources say are the best anyway. Pushed them out with a combination of using the vice and some bashing: While ordering parts I finally replaced the bonnet stopper jobbies. This one was... New ones look nice, no photo though. Also the drag link had play in it, it's the factory one which is not rebuildable (well economically anyway). So replaced it with an upgraded heavy duty chromoly one with replaceable ends: The rear brake light has had a crack in it for as long as I can remember, wof man didn't like it. So bought a new one. It's so clean and not sun faded! The main wof fail was rust hidden behind the radiator, it's likely been like that for all 10 years. It took a wof inspector who's knows the problem area to actually find it. It honestly took about 10 minutes trying to find it myself, it's that difficult to see. Real pain in the ass to fix but go it done. I missed the 28 days because I injured my back (unrelated) then got covid (probably also unrelated). Only photo I can find, which is actually the front where I reinforced it, not the prettiest but it's solid. The bad bit was behind this on the other side in a tight spot. That wire is just a 'zip tie' holding the A/C condenser out of the way. So ended up getting another wof check at the same place, all passed but now noted that the radius arm bushes need doing soon. Old cars man... 4 Quote
~Slideways~ Posted September 26, 2023 Author Posted September 26, 2023 Had to change the radius arm bushes for a wof, man what a bastard to get out. I had this press frame from my wifes uncle years ago, never used it because it didn't come with a hydraulic ram or anything. Now, it looks to me that it was designed to use a bottle jack, but from the bottom. Bought a cheap 20T bottle jack, with the intention of modifying it to work upside down. But it worked reasonably well as is, pretty awkward balancing it though. At first it just pushed the rubber out and left the outer sleeve behind. So I tried a few different things the same diameter as the outer sleeve but they all bent or crushed. That sleeve was not wanting to come out, so I cut a slot in it and chiseled it out. Then I made a round plate the diameter of the outer sleeve, out of 10mm mild steel flat bar. I thought that'd easily work. Snapped one bolt in the frame, doesn't look like high tensile to me though. Found some more better bolts. Tried again and got one out with a loud crack each time it moved another 5mm. Even bent the 10mm plate. New Nissan Genuine bushes as well as the rear chassis/frame mount ones. I made another 10mm plate with a hole in the centre for the centre sleeve to rest in while pushing against the outer sleeve. They went back in nicely, super satisfying after the bastard it was to get the old ones out. Few hundred in bushes but it'll last another few decades hopefully. EDIT: Wof man laughed and said he's done heaps of them and the press fittings get ruined after doing only a couple. Sometime you have to gas axe the bolts/bushes at the rear of the arm as well. So I guess I got off lightly. EDIT2: yes my workshop is a mess. I'm reorganising while putting up more shelves... that's the excuse at the moment anyway. 7 Quote
Popular Post ~Slideways~ Posted November 16, 2025 Author Popular Post Posted November 16, 2025 So when I bought this around a decade ago it already had the snorkel installed. A while ago I noticed rust staining coming from under it at the centre point, I assumed the bolt hole had started to rust and there was also a dent there. HoOooBoy did I underestimate it... I tried looking around for a good condition guard but had no luck so decided to try save it. Patches welded in, of course I ran out of gas half way. Spent lots of time making it flat again then primed and blocked (around 9:30pm in the dark because who has time anymore?). EDIT: I also trimmed a decent about off the lower section to clear 35's, added a lip for strength etc. 2k blackest black that ever blacked: Fitted again and it makes the 35 year old tired paint look terrible so will repaint the whole thing at some stage. 11 Quote
