flyingbrick
Arduino stuff/ programing/so cheap
14 hours ago, Ned said:
why are you still dicking around with this? just buy a speeduino board, and start writing code... those ignition drivers all work etc as well as give you lots of other inputs you're going to need...
or you doing it purely as an exercise on how to drive coils/learn something? I dont understand why you are using a fet to drive an IGBT to drive a coil, when you can just use a fet to drive the coil
Doing it to prove i can.
And i've driven the coils from mosfets many times & burnt up every one of them.
Share this post
Link to post
Just bought some STM32H7 dual core processors.
Now all that's left to figure out is... Everything :pukeright:
  • Haha 1
Share this post
Link to post
18 hours ago, Ghostchips said:
Doing it to prove oldschool can.
:-D
Share this post
Link to post
Ordered an arduino due off of ali today. Not sure what I will use it for, but the extra speed may outweigh the lack of 5V capability for some applications (32 bit, 84 MHz ARM cpu)
Share this post
Link to post
On 13/06/2019 at 22:19, Ned said:
mechanical switches bounce, thats just the nature of them. Add SW debouncing by checking the signal is valid for 30mS or something, or do hardware debouncing with a 100nF capacitor across the switch and a weak pullup? 10k or bigger maybe? i dont usually do HW debouncing as it costs more than a few lines of code so might pay to google a bit....
So I tried adding a resistor to put the pin down to ground but still had triggering issues from the machinery running around it. How does a pull up work?. If I posted the code on here could ya point me in the right direction? Cheers!!!
Share this post
Link to post
Teensy range is bloody good too, and as the name would suggest, uhhh... teensy. for if you need something with a smaller footprint than the Due.
https://www.pjrc.com/teensy/
Share this post
Link to post
You need to do some of the basic arduino tutorials on this, makes heaps of sense after
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
