  • Replies 58
I cut out some holes for the go fast knee scallops, these large openings were quite handy as after i ground out the large amount of filler i could get in there with a dolly and get rid of all the dents, the tank is now real smooth and fair
also made up a little fill in patch for the front of the seat to blend into
after a good sanding to remove the surface rust
  • Like 9
Turning up the pivot
And tapping out the original passenger foot peg mounts 7 1/6 unf for the new pegs to screw into IMG_2082.thumb.JPG.065f99a2b743825406e5d2668694d6cb.JPG
You wouldn't happen to have a spare set of flywheels would you? I have big box of bantam engine parts if you need anything?
Thanks Kimjon! Just need to keep the progress going like you do and it will be finished in no time haha.   No I don't have any other flywheels sorry SOHC, I'm pretty sorted in the engine department I think, do you have any ignition bits? A mate has just brought a bantam but it's missing all of that stuff.  I may need to find another front hub assembly though if you had one of those though?
I can sort out the ignition bits, I have the stator plate, a few stators, ignition coils, I may not have any good lighting coils, I can do you a new front hub
Will send you a pm about bits SOHC, a new hub would probably be a bit good for what I'm planning on doing with it though.
Thanks for the comments LG and Toucan!
Sorry its not a new hub, it needs a repair but its usable
